okay sorry it's flashing now i didn't realize it wasn't plugged into pin 12
the values pop up on the serial monitor now
What IR code do you want to use to make the servo to go to 120° ?
What IR code do you want to use to make the servo to go to 25° ?
for 120° i would like 46, and for 25° i would like 15
- Try this test sketch to see if the servo moves when the IR remote buttons are pressed.
// Servo.ino
// https://forum.arduino.cc/t/cant-figure-out-how-to-control-servo-with-ir-remote/1422403
// LarryD
// Version YY/MM/DD Comments
// 1.00 25/12/29 Running code
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
//use IRremote library version 4.4.0 or newer
#include <IRremote.hpp>
#define DECODE_NEC
#define LIGHTon 0x46 //Up Arrow
#define LIGHToff 0x15 //Down Arrow
#define SERVOmax 120
#define SERVOmin 25
const byte IR_RECEIVE_PIN = 12;
const byte heartbeatLED = 13; //Optional, toggles every 500ms
//timing stuff
unsigned long heartbeatTime;
unsigned long checkRemoteTime;
// s e t u p ( )
pinMode(heartbeatLED, OUTPUT);
myservo.attach(8); // attaches the servo on pin 8 to the servo object
//start the receiver
IrReceiver.begin(IR_RECEIVE_PIN);
} //END of setup()
// l o o p ( )
//======================================================================== T I M E R heartbeatLED
//is it time to toggle the heartbeat LED ?
if (millis() - heartbeatTime >= 500ul)
//restart this TIMER
heartbeatTime = millis();
//toggle the heartbeat LED
digitalWrite(heartbeatLED, digitalRead(heartbeatLED) == HIGH ? LOW : HIGH);
//======================================================================== T I M E R checkRemote
//is it time to check for a new IR remote character ?
if (millis() - checkRemoteTime >= 10ul)
checkRemoteTime = millis();
checkRemote();
// other non blocking code goes here
} //END of loop()
// c h e c k R e m o t e ( )
void checkRemote()
//have we received an IR code ?
if (IrReceiver.decode())
//determine which button was pressed
if (IrReceiver.decodedIRData.command != 0)
byte byteRX = IrReceiver.decodedIRData.command;
//we will ignore repeat codes
IrReceiver.decodedIRData.command = 0;
Serial.print("Code: ");
//should we add a 0 prefix ?
if (byteRX <= 0xF)
Serial.print("0");
Serial.println(byteRX, HEX);
if(byteRX == LIGHTon)
myservo.write(SERVOmax);
myservo.write(SERVOmin);
} //END of if (IrReceiver.decodedIRData.command != 0)
//restart IR code detection
IrReceiver.resume();
} //END of checkRemote()
it moves when i press the buttons now!
from what i can tell the 6v conection is connected to ground and has a switch that's connected to the positive on the servo
Common hobby servos can be powered from 4.5V to 6V (some can work at7V).
As mentioned do not power a motor from the Arduino 5V pin.
Doing so can damage your Arduino. -
There must be a common GND connection between the Arduino and Servo power supply as seen in the schematic.
The Heartbeat LED should toggle every 1 second.
It gives us a rough indication our sketch is running and our code is non-blocking.
This LED is optional but I like using it.
The on board "L" LED will also toggle at a 1 second rate.
So, I was able to get the code to work with a smaller servo motor, but I ended up having to get a 25g because the old one didn't have enough torque. When i plugged in the 25g servo it just kept turning without pressing any button. Do you have any ideas on how to fix that?
- Sounds like you purchased a continuous servo as discussed earlier in this thread.
so i'm assuming i can't use this servo for the purpose that i intended it for?
- For an ON/OFF application like this you need a normal servo one that goes from 0° to 180°.
how can i differntiate the two before i purchase one? what should I be on the lookout for?
do you think an mg90s would be good? I feel like I would need a smaller form factor
never mind, I looked up the data sheet for both and I feel like i would run into the same issues as the sg90 i'm currently using
the hobby store i got it from didn't have anything that stated that it was continuous rotation on the packaging sadly, I should've done more research but I was just impatient
I ended up buying a 2 pack on amazon, I will keep you posted on that. Thank you so much for all of your help!
