I have a sketch that converts a input string from a program using Azimuth/Elevation to create X/Y numbers.
The sketch works fine except when the input equals zero degrees for both Azimuth and Elevation.
So a input like 0,0.0,0.0 gives only a X and nothing else.
A input like 0,1.0,1.0 gives a correct output.
Maybe someone could have a look at the sketch.
// Detect a Videre command that looks like 1,aaa.a,eee.e
// if e = negative where waiting for a satilite
#include <Wire.h>
#include <Streaming.h>
#include <Servo.h>
#if defined(ARDUINO) && ARDUINO >= 100
#define printByte(args)  write(args);
#else
#define printByte(args)  print(args,BYTE);
#endif
String readString = "";
float x_axisTemp = 0;
float y_axisTemp = 0;
int videreIndex = 0;              // counter if a Videre command is to be decoded
int decimalPoint = 0;
int dataEastWest = 0;
int teller = 0;
//long _XX = 0L;
//long _YY = 0L;
float newXaxis = 0L;	// new azimuth for rotor move
float newYaxis = 0L;	// new azimuth for rotor move
static const double DegreeToRadian = PI/180. ;  // PI/180
static const double RadianToDegree = 1/DegreeToRadian;    // 1 / ( PI / 180 )
boolean videreCommand = false;    // Is set if the first character received is a 0 or 1
boolean videreEastWest = false;   // Set if the pass is on the QTH-West
// Create display instance
//  Arduino analog input 5 - I2C SCL
//  Arduino analog input 4 - I2C SDA
LiquidCrystal_I2C lcdSerial(0x20,20,4);  // set the LCD address to 0x20 for a 20 chars and 4 line display
Servo X_AXIS;  // create servo object to control a servo
  Serial.begin(19200);
  Serial.println("Videre Command 0.0"); // so I can keep track of what is loaded
  lcdSerial.init();                      // initialize the lcd
  lcdSerial.backlight();
  lcdSerial.print(" Videre Command 0.0"); // so I can keep track of what is loaded
  X_AXIS.attach(6);  // attaches the servo on pin 9 to the servo object
  X_AXIS.write(90);    // And place it at the zero position
  delay(5);
  if (Serial.available())  {
    readCommand(Serial.read());
  else  {
void readCommand(char character)  {
  if (character == ',' || character == '\n' || character == '\r') {
    if (readString.length() >0) {
      switch(videreIndex)  {
      case 0:
          if(readString == "0" && !videreCommand)   {
            Serial << "Pass on West so add 180 degrees (flip)" << endl;
            videreCommand = true;
            videreEastWest = true;
            videreIndex = 1;
          else if(readString == "1" && !videreCommand)   {
            Serial << "Pass on East no adjustment needed" << endl;
            videreIndex = 1;
      case 1:
          x_axisTemp = convertToFloat(readString);
          Serial << "Got X value = " << x_axisTemp << endl;
          if(x_axisTemp > 360)  {
            videreIndex = 0;
          else  {
            videreIndex = 2;
          readString = ""; //clears variable for new input
      case 2:
          y_axisTemp = convertToFloat(readString);
          Serial << "Got Y value = " << x_axisTemp << endl;
          if(y_axisTemp <= 000.0)  { // Waiting for satelite to come in range
            y_axisTemp = 000.0;
            if(videreEastWest)  {
              y_axisTemp = 180.0;
            else  {
              y_axisTemp = 000.0;
          if(y_axisTemp <= 180.0)  {
            lcdSerial.setCursor(0,1);
            lcdSerial << "AZ/EL " << displayAxis(x_axisTemp);
            lcdSerial.setCursor(13,1);
            lcdSerial << displayAxis(y_axisTemp);
            xyConvert(x_axisTemp, y_axisTemp);
            lcdSerial.setCursor(0,2);
            lcdSerial << " X/Y  " << displayAxis(newXaxis);
            lcdSerial.setCursor(13,2);
            lcdSerial << displayAxis(newYaxis);
            lcdSerial.setCursor(0,3);
            lcdSerial << "Rotor " << "  0.00   0.00";
            X_AXIS.write(newXaxis);
          else {
            Serial << "Wrong elevation, start over again " << endl;
          videreIndex = 0;
      default:
          Serial << "Some Error" << endl;
  else {
    readString += character; //makes the string readString
float convertToFloat(String readString)  {
  char carray[readString.length() + 1]; //determine size of the array
  readString.toCharArray(carray, sizeof(carray)); //put readStringinto an array
  float f = atof(carray); //convert the array into a float
String displayAxis(double axis)  {
  static char Buffer[7];
  String SString = "";
  if(axis < 10.0)   {
    SString += " ";
  if(axis < 100.0)  {
    SString += " ";
  dtostrf(axis,4, 2, Buffer);
  return SString += Buffer;
void xyConvert(float az, float el)  {
  double azFloat = az * DegreeToRadian;        // One can also use DEG_TO_RAD
  double elFloat = el * DegreeToRadian;
  double _XX = 0L;
  double _YY = 0L;
  _XX = asin(sin(azFloat)*cos(elFloat)) * RadianToDegree;        // One can also use RAD_TO_DEG
  if(el < 0.1) {
    _YY = 000.1;
  if(el == 180)  {
    _YY = -090.0;
  else {
    _YY = atan(cos(azFloat)/tan(elFloat)) * RadianToDegree;
  newXaxis = 90 - _XX;
  newYaxis = 90 - _YY;
float RadiansToDegrees(float rads)
  float RTD = rads * 180/PI;
  return RTD;
