Hi
I have a code where I have delay added 3 times. It all works nicely in the beginning as long as the if sentence is false and it uses delay (6000); in the end of the code. When the if sentence is valid it then halts for the first delay for 1 second but it just skips all other delays, even if the if sentence is not valid anymore. Anyone have any esy suggestions on what could be wrong, I have tried to look around in the internet but can't seem to find a solution.
int analogPin = A3; // potentiometer wiper (middle terminal) connected to analog pin 3
// outside leads to ground and +5V
int val = 0; // variable to store the value read
int delay1 = 6000;
int delay2 = 1000000;
//Pumpemotor
int pinOut = 10;
//Vannmengdemaaler
volatile int NbTopsFan; //measuring the rising edges of the signal
int Calc;
int hallsensor = 2; //The pin location of the sensor
void rpm () //This is the function that the interupt calls
NbTopsFan++; //This function measures the rising and falling edge of the
//Pumpe
pinMode(10, OUTPUT);
Serial.begin(9600); // setup serial
//Vannmengdemaaler
pinMode(hallsensor, INPUT); //initializes digital pin 2 as an input initialised,
attachInterrupt(0, rpm, RISING); //and the interrupt is attached
delay (6000);
val = analogRead(analogPin); // read the input pin
Serial.println(val); // debug value
//pumpemotor
if (val >= 430){
digitalWrite(pinOut, HIGH);
Serial.print ("Slår på pumpe og venter 10 sekunder\r\n");
//Vannmengdemaaler
NbTopsFan = 0; //Set NbTops to 0 ready for calculations
sei(); //Enables interrupts
delay (1000); //Wait 1 second This delay always works
cli(); //Disable interrupts
Calc = (NbTopsFan / 7.5); //(Pulse frequency x 60) / 7.5Q, = flow rate in L hour
Serial.print (Calc, DEC); //Prints the number calculated above
Serial.print (" L/minute\r\n"); //Prints "L/minute" and returns a new line
digitalWrite(pinOut, LOW);
Serial.print ("Before delay\r\n");
delay (delay2); //This delay never works
Serial.print ("After delay\r\n");
else {
Serial.print ("Ok fuktighet, venter 60 sekund\r\n");
delay(6000); //This delay works until the if sentence above is valid, after the if sentence has been valid once it does not work anymore
