So I followed the instructions for the ESP8266 on instructables.com and when I typed "AT" to the serial monitor expecting "OK" i got:
. How do I fix this?
Is your baudmode 115200 ?
No, it doesn't do anything then. I tried every one, the highest baud rate that works is 4800 I think.
But it says :
are you using a ESP-01?
what host microcontroller are you using?
how is the host connected to the ESP8266?
I am using the ESP-01 connected to my UNO R3
The pinout is:
Gnd => Gnd
En => 3.3V
VCC => 3.3V
Tx => Tx
Rx => Rx
I might be missing something but I am pretty sure I wired it correct.
That is what the tutorial tells you to do, but i recommend a voltage divider on the ESP's RX line
UNO RX -> 1K -> ESP-RX -> 1K -> 1K -> GND
The ESP pins are not 5v tolerant and so the 5v logic level of the UNO should be reduced to prevent damage.
Also add a connection between Vcc(3.3v) & RST. Nearly all ESP-01 boards have a 10K pullup on that pin, but not all of them.
The most common firmware that is preloaded on the ESP-01 runs at 115200 bps, on rare occasions a firmware that uses 9600 bps is present. 4800 bps i have never encountered.
again, make sure of the following
- There is nothing from the ATmega chip interfering with the USB to TTL converter. So upload bare-minimum or even better 'Blink' to the UNO
- Set the Serial monitor baudrate to 115200 bps
- Set line ending to 'Both CR & LF'
- Add the voltage divider to you circuit (use 1K resistors, not higher values)
- Add a 10K pullup to the RST pin
Even if i do not think that using AT-commands is the way to go in the long run, getting them to work is a relevant step in getting a handle on the ESP-01
So I conect the Uno RX to a 1k resistor before it connects to the ESP-RX?
Yes, and the from there you connect 2 more 1k resistors in series to GND.
Basic electronics will then result that if 5v comes from the UNO RX, 3.33v will end up at the ESP RX
Hey @Deva_Rishi? Quick question, do I connect Tx to Rx and Rx to Tx or Tx to Tx and Rx to Rx?
I have used
UNO GPIO9 Tx to ESP-01 GPIO3 U0RX
UNO GPIO8 Rx to ESP-01 GPIO1 U0TX
![image|690x498]
running the following code
// UNO - ESP-01 AltSoftSerial test - ESP-01 loopsback - character transmitted to it are echoed back
// requires program ESP-01_Serial_loopback loaded in to ESP-01 and serial connections (see below)
// note that at baudrates above 38400 some echoed characters are corrupted
#include <AltSoftSerial.h>
// load program ESP-01_Serial_loopback in to ESP-01
// ESP-01 U0TXD to UNO RX pin 8
// ESP-01 U0RXD to UNO TX pin 9
// ESP-01 GPIO0 and GPIO2 need to have pull-up resistors connected to ensure the module starts up correctly
// The ESP-01S has 12K resistors on the board for GPIO0, RST and CH_PD
AltSoftSerial espSerial;
Serial.println("AltSoftSerial test");
//Begin serial communication with Arduino and SIM800L
espSerial.begin(38400);
Serial.println("ESP-01 serial intialized");
Serial.println("load ESP-01_Serial_loopback in to ESP-01");
Serial.println("ESP-01 U0TXD to UNO RX pin 8");
Serial.println("ESP-01 U0RXD to UNO TX pin 9");
if (Serial.available()) {
char command = Serial.read();
//Serial.println(command);
espSerial.print(command);
while (espSerial.available()) {
char reponse = espSerial.read();
Serial.print(reponse);
All I get in serial monitor is gibberish and
just connected a new ESP-01S module to an ESP32
tried ESP-01 baudrate 38400 and it did not work
then tried baudrate 115200 and it displays when entering commands AT and AT+GMR (check version information)
AT
OK
AT+GMR
AT version:0.40.0.0(Aug 8 2015 14:45:58)
SDK version:1.3.0
Ai-Thinker Technology Co.,Ltd.
Build:1.3.0.2 Sep 11 2015 11:48:04
OK
you can try ESP-01 at 115200baud on the UNO but it probably will not work (bit bash software serial tends to fail at baudrates over 38400)
If you just want to try and write AT-commands sstraight from the Serial monitor then use
If it all still doesn't work, there are a few possibilities
- Somehow there is something which is not connected the way it is supposed to be. Can you post a picture of how you have connected it ? I tend to recommend to disconnect everything and the reconnect everything, as that sometimes makes things show up.
- The ESP does not have AT-firmware uploaded onto it at all (it happens, it's rare but it does)
- The ESP is faulty.
Anyway first post a picture. please.
Here is a photo of my wiring:
Very nice but that is a picture of your schematic, with the voltage divider still missing btw.
What i meant is a picture of what it actually look like. I have had people sticking wires in the wrong holes on the breadboard.
You should remove D1
Yeah it's not a very good picture. It doesn't contain the voltage divider and lighting is very poor.
Is CH_PD (EN) also connected to 3.3v ? What kind of UNO is that btw ?
