Can't get the ethernet spi to work
Hello,
i run into some big Problems with my Ethernet SPI. But first things first: my goal is to connect two/three or more Arduinos via Ethernet using direct connection via Crossover cabel or through a switch (this i also not working atm, but i take some small steps now). At this moment i cant belive that this will ever work, but we will see when time goes on.
After reading on this Forum and other sources i finally come to the decision to make a post, because nothing worked out so far.
The main Problem ist that i cant get my Ethernetshield to run.
Link for the Ethernet shield: Ethernet Module
Link from the Ardruino: arduino uno
I can also confirm that it is the wiznet chip W5500 on this Module.
So i was trying the WebClint Example from the standard Ethernet lib, which should be work (also tried Ethernet2 and Ethernet3 with same results).
Code is following:
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xBB };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
char server[] = "www.google.com";  // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
IPAddress myDns(192, 168, 0, 1);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// Variables to measure the speed
unsigned long beginMicros, endMicros;
unsigned long byteCount = 0;
bool printWebData = true;  // set to false for better speed measurement
  // You can use Ethernet.init(pin) to configure the CS pin
  Ethernet.init(10);  // Most Arduino shields
  //Ethernet.init(5);   // MKR ETH Shield
  //Ethernet.init(0);   // Teensy 2.0
  //Ethernet.init(20);  // Teensy++ 2.0
  //Ethernet.init(15);  // ESP8266 with Adafruit FeatherWing Ethernet
  //Ethernet.init(33);  // ESP32 with Adafruit FeatherWing Ethernet
  while (!Serial) {
    ;  // wait for serial port to connect. Needed for native USB port only
  // start the Ethernet connection:
  Serial.println("Initialize Ethernet with DHCP:");
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // Check for Ethernet hardware present
    if (Ethernet.hardwareStatus() == EthernetNoHardware) {
      Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
      while (true) {
        delay(1);  // do nothing, no point running without Ethernet hardware
    if (Ethernet.linkStatus() == LinkOFF) {
      Serial.println("Ethernet cable is not connected.");
    // try to configure using IP address instead of DHCP:
    Ethernet.begin(mac, ip, myDns);
    Serial.print("DHCP assigned IP ");
    Serial.println(Ethernet.localIP());
  // give the Ethernet shield a second to initialize:
  Serial.print("connecting to ");
  Serial.print(server);
  Serial.println("...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.print("connected to ");
    Serial.println(client.remoteIP());
    // Make a HTTP request:
    client.println("GET /search?q=arduino HTTP/1.1");
    client.println("Host: www.google.com");
    client.println("Connection: close");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  beginMicros = micros();
  // if there are incoming bytes available
  // from the server, read them and print them:
  int len = client.available();
  if (len > 0) {
    byte buffer[80];
    if (len > 80) len = 80;
    client.read(buffer, len);
    if (printWebData) {
      Serial.write(buffer, len);  // show in the serial monitor (slows some boards)
    byteCount = byteCount + len;
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    endMicros = micros();
    Serial.println("disconnecting.");
    client.stop();
    Serial.print("Received ");
    Serial.print(byteCount);
    Serial.print(" bytes in ");
    float seconds = (float)(endMicros - beginMicros) / 1000000.0;
    Serial.print(seconds, 4);
    float rate = (float)byteCount / seconds / 1000.0;
    Serial.print(", rate = ");
    Serial.print(rate);
    Serial.print(" kbytes/second");
    // do nothing forevermore:
    while (true) {
      delay(1);
This Code will stuck at:
i modify the code so i skip the dhcp init and go for a static ip:
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
  while (!Serial) {
  delay(5000);
    delay(3000);
      while (true) {
    Serial.println(Ethernet.hardwareStatus());
    client.println();
  if (len > 0) {
    byte buffer[80];
    if (printWebData) {
    client.stop();
    Serial.print(rate);
    while (true) {
      delay(1);
which give me this output:
192.80.0.136
3
connecting to www.google.com...
Somehow the ip is now diffrent from my ip adresse at the top
if i change the ip adress to something like 10.0.0.1 i got the right adress from Ethernet.localIp, changing back to 192.168.0.177 gives me 192.80.0.136 again. If i change the pc and upload there i become a diffrent adress with the same code like 192.80.1.98 this is all tested with and without connected LANcable.
I also used different Arduinos, Ethernet moduals and PC's. I also double checked the jumpers. LED on the Module is red, when i put it an LANcable Connector is turning green and transfer led is blinking.
My router normally supports DHCP, no macfilter is active, lancable is working on my PC
Libary and IDE is up to date and lancable is normally connect to my pc and my router.
Arduino and Module are new.
Somehow the second Code worked for one time, with a ethablished connection to the google endpoint. But i cant reproduce it. The next time i hit the reset button same problem as before, with no code changed.
Hopefully i didn't forget any information. Every Idea/Thoughts are welcome.
Cheers
I would like to see an annotated schematic showing how this was wired.
Hope that fits
Wired shematic:
Pins used:
Other pins are connected to 5V, GND, RST
