#include <HardwareSerial.h>
HardwareSerial MySerial(1);
Serial.println("Starting the sender (white board)....");
MySerial.begin(9600, SERIAL_8N1, 16, 17);
// Send a random number
MySerial.write(random(0, 255));
I have pin 16 of the Receiver connected to pin 17 of the Sender, and pin 17 of the Receiver connected to pin 16 of the Sender. And they're sharing ground and 3.3v pins.
Does anyone happen to have any ideas?
Edit: and I know there are better ways to communicate between two ESP32s, but my eventual goal is to send messages to an ESP32 (so it can upload the data) from an Arduino. Basically trying to slave an ESP32 for wifi.
How are both ESP32 powered? Are you trying to supply the second ESP32 through the 3.3V pin of the first one? This will not work. The ESP32 produces current-spikes 300 mA high.
me personal I always add a piece of code that makes the onboard-led blink as a "heartbeat" to visually indicate code is running.
I powered both ESP32s with their own USB-cable. And in this configration this code works
You can use the code on both ESP32 they send back and forth a byte.
#define dbg(myFixedText, variableName) \
Serial.print( F(#myFixedText " " #variableName"=") ); \
Serial.println(variableName);
// usage: dbg("1:my fixed text",myVariable);
// myVariable can be any variable or expression that is defined in scope
#define dbgi(myFixedText, variableName,timeInterval) \
do { \
static unsigned long intervalStartTime; \
if ( millis() - intervalStartTime >= timeInterval ){ \
intervalStartTime = millis(); \
Serial.println(variableName); \
} while (false);
void PrintFileNameDateTime() {
Serial.println( F("Code running comes from file ") );
Serial.println( F(__FILE__) );
Serial.print( F(" compiled ") );
Serial.print( F(__DATE__) );
Serial.print( F(" ") );
Serial.println( F(__TIME__) );
boolean TimePeriodIsOver (unsigned long &expireTime, unsigned long TimePeriod) {
if ( currentMillis - expireTime >= TimePeriod ) {
expireTime = currentMillis; // set new expireTime
return true; // more time than TimePeriod) has elapsed since last time if-condition was true
else return false; // not expired
unsigned long MyTestTimer = 0; // Timer-variables MUST be of type unsigned long
const byte OnBoard_LED = 2;
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
static unsigned long MyBlinkTimer;
pinMode(IO_Pin, OUTPUT);
if ( TimePeriodIsOver(MyBlinkTimer, BlinkPeriod) ) {
digitalWrite(IO_Pin, !digitalRead(IO_Pin) );
Serial.println("Setup-Start");
PrintFileNameDateTime();
uint8_t myByte = 48;
BlinkHeartBeatLED(OnBoard_LED, 100);
while (MySerial.available() > 0) {
uint8_t byteFromSerial = MySerial.read();
dbg("received", byteFromSerial);
if ( TimePeriodIsOver(MyTestTimer, 1000) ) {
MySerial.write(myByte);
myByte++;
if (myByte > 59) {
myByte = 48;
Very nice, lots of interesting things happening in your script, lots for me to learn there.
But alas, I installed it on both boards, still nothing in the Serial Monitor.
(And I'm powering both boards from the same laptop, but to be safe one board is powered with a USB micro that doesn't have data lines. Only connecting ground and the tx/rx pins as in the pic above).
For connecting a 5V-Arduino to a 3.3V ESP32 you should use voltage-level-converters.
For Arduino sends to ESP32 a simple voltage-divider would be sufficient.
For sending from the ESP32 to an 5V arduino voltage-level-shifting is nescessary.
best regards Stefan
For sending data from an arduino to an ESP32 over serial I recommend reading
@UkHeliBob is right, it works without an external library. See my updated scripts below.
don't power both ESP32's from the same computer. The tests didn't work until I plugged the sender into a wall USB charger.
keep a lot of ESP32s on hand, ideally from different vendors, because for some reason that Rover ESP32 still doesn't work with these tests, but every one of my cheaper Wrooms do. With the bad ESP32 and the issue of powering both chips from the same computer, this was a tough riddle.
For wiring, connect pin 16 of the Sender ESP32 to pin 17 of the Receiver ESP32, connect pin 17 of the Sender to pin 16 of the Receiver, and connect a ground pin of Sender to a ground pin of Receiver. And if it doesn't work at first, try powering the Sender ESP32 from a different source, not just another port on the same computer.
And thanks for the tip @stefanL38 about a voltage divider, I'll give that a try. I only need to send data from the Arduino to the ESP32, so that should work.
Whoo hoo! This works as a Sender when running on an Arduino Uno, both with and without a voltage divider... I'm guessing I'd be wise to use a voltage divider though?
And interestingly the Arduino doesn't seem to mind being powered by the same laptop as the ESP32.
Sender (version for Arduino Uno, connect Arduino tx pin (1) to ESP pin 16 and connect Arduino ground to ESP32 ground):
