Hi all,
Can someone please explain this to me. I am trying to increment the "SendMessage" (which is an int variable) value to "2", inside an "if()" statement, but it doesn't increment.
Here's the sketch:
int Sensor1 = A8; //Optocoupler input
int Sensor2 = 37; //Optocoupler input2 (Digital 37, mapped to DB0 on Gboard PRO
int SensorState = 0;
int SendMessage = 0;
pinMode(Sensor1, INPUT);
pinMode(Sensor2, INPUT);
digitalWrite(Sensor1, HIGH);
digitalWrite(Sensor2, HIGH);
} // end setup()
void loop() // run over and over again
CheckSignal();
} // End loop
void CheckSignal()
if(digitalRead(Sensor1) == LOW || digitalRead(Sensor2) == LOW) // See if either sensors are active
SensorState = 1;
SendMessage = 1;
if (SendMessage == 1)
Serial.println("Message Sent");
Serial.print("SensorState: ");
Serial.println(SensorState);
Serial.print("SendMessage: ");
Serial.println(SendMessage);
SendMessage = 2;
SensorState = 2;
SendMessage = 2;
} // end ditigalRead(Sensor1) or digitalRead(Sensor2)
} // end CheckSignal()
And here's the sample output:
SendMessage: 1
Message Sent
SensorState: 1
SendMessage: 1
Message Sent
SensorState: 1
SendMessage: 1
Message Sent
SensorState: 1
SendMessage: 1
Message Sent
SensorState: 1
SendMessage: 1
Message Sent
SensorState: 1
SendMessage: 1
In theory, each of those lines should be printed once only, and the "SendMessage" int variable should increase to "2", but it doesn't. Why would that be?
