OK, I have spent a whole day before I thought i would bother anyone.
I have run this through GPT5 and the AI Assistant on Arduino Cloud.
I simly wanted to use the sensor BM280, You know, a simple IoT sketch for the Arduino R4 WiFi but wanted to feed to Adafruit IO.
It tells me again and again that I have not installed the Adafruit IO Arduino library> But I have. About 20 times, incl tbhorugh Github.
I am using the IDE and when I comile, it always gets stuck at
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
The Error statements states:
Compilation error: 'AdafruitIO_WiFi' does not name a type; did you mean 'Adafruit_BME280'
The Ai assistant on Arduino always states that it means the above library has not been propoerly installed.
my code is as follows:
#include <AdafruitIO_WiFi.h>
#include <WiFiS3.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
//Second, need to insert "credentials" for both home Wifi and Adafruit Io
#define IO_USERNAME "tflahvin"
#define IO_KEY "\[my key is deleted from this post}"
#define WIFI_SSID "ORBI75"
#define WIFI_PASS "ancientsun137"
// Third, create Adafruit IO instance (uses the underlying WiFi client)
// Fourth, create the 3 "feeds"
AdafruitIO_Feed \*temperature = io.feed("temperature");
AdafruitIO_Feed \*humidity = io.feed("humidity");
AdafruitIO_Feed \*pressure = io.feed("pressure");
//Fifth, draw on the "class" from the Adafruit BME289 Library
Adafruit_BME280 bme; // I2C
/\* An exlanation of the above:
The class is basically a blueprint for how to talk to the BME280 sensor chip (via I²C or SPI).
//OK, now into setp
delay(200);
Serial.print("Connecting to Adafruit IO");
io.connect();
while (io.status() < AIO_CONNECTED) { //in ohewr other words while NOT connected
Serial.print(".");
io.run(); //while waiting for connection and reading.
Serial.println("\\nAdafruit IO connected.");
//Now initiate the sensor
if (!bme.begin(0x76)) {
if (!bme.begin(0x77)) {
Serial.println("Could not find BME280! Check wiring and address.");
while (1) { delay(10); }
// Required to keep the Adafruit IO client alive
io.run();
//Now read the sensor
float t = bme.readTemperature();
float h = bme.readHumidity();
float p = bme.readPressure() / 100.0F;
// Now publish the feeds
temperature->save(t);
humidity->save(h);
pressure->save(p);
// Now print on monitor to see if working propoerly
Serial.print("T: "); Serial.print(t); Serial.println(" °C" );
Serial.print("H: "); Serial.print(h); Serial.println(" %" );
Serial.print("P: "); Serial.print(p); Serial.println(" hpa ");
delay(20000);
Hi @tflahvin .
I'm going to ask you to provide the full verbose output from a compilation.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
Open your sketch in Arduino Cloud Editor .
Click the "Settings" icon at the bottom left corner of the page:
The "Settings " panel will open.
Select the "Verbose output " radio button under the "Console verbosity " section of the "Settings " panel.
Click the ✓ button in the Cloud Editor toolbar.
Wait for the compilation to fail.
If the black "Console " panel at the bottom of the Cloud Editor page is minimized, click the ˄ icon at the right side of the "Console " toolbar to expand it.
Click the icon in the top right corner of the black "Console " panel at the bottom of the Cloud Editor page that looks like two pieces of paper ("Copy Console Output"):
Open a reply here on this forum topic by clicking the "Reply " button.
Click the <CODE/> icon on the post composer toolbar.
This will add the forum's code block markup (``` ) to your reply to make sure the error messages are correctly formatted.
Press the Ctrl +V keyboard shortcut (Command +V for macOS users).
This will paste the compilation output into the code block.
Move the cursor outside of the code block markup before you add any additional text to your reply.
Click the "Reply " button to publish the post.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
Open any text editor program.
Paste the copied output into the text editor.
Save the file in .txt format.
Click the "Upload" icon ( ) on the post composer toolbar:
The "Open " dialog will open.
Select the .txt file you saved from the "Open " dialog.
Click the "Open " button.
The dialog will close.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Firstly, thanks so much.
I could not copy text of verbose message. It was too large.
Also for some reason I could not attach a text document. Strange.
So will paste text in 2 separete relies. I hope that is ok..
First is below:
FQBN: arduino:renesas_uno:unor4wifi
Using board 'unor4wifi' from platform in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0
Using core 'arduino' from platform in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0
Detecting libraries used...
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp -o /dev/null
Alternatives for AdafruitIO_WiFi.h: [Adafruit IO Arduino@4.3.2]
ResolveLibrary(AdafruitIO_WiFi.h)
-> candidates: [Adafruit IO Arduino@4.3.2]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp -o /dev/null
Alternatives for WiFiS3.h: [WiFiS3@0.0.0]
ResolveLibrary(WiFiS3.h)
-> candidates: [WiFiS3@0.0.0]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp -o /dev/null
Alternatives for Wire.h: [FlexWire@1.2.1 Wire]
ResolveLibrary(Wire.h)
-> candidates: [FlexWire@1.2.1 Wire]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp -o /dev/null
Alternatives for Adafruit_Sensor.h: [ClimaStick@1.3.1 Adafruit Unified Sensor@1.1.15]
ResolveLibrary(Adafruit_Sensor.h)
-> candidates: [ClimaStick@1.3.1 Adafruit Unified Sensor@1.1.15]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp -o /dev/null
Alternatives for Adafruit_BME280.h: [Adafruit BME280 Library@2.3.0]
ResolveLibrary(Adafruit_BME280.h)
-> candidates: [Adafruit BME280 Library@2.3.0]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp -o /dev/null
Alternatives for Adafruit_I2CDevice.h: [EIS@0.0.1 Adafruit BusIO@1.17.2 EIS_INTERBOT@1.0.0 VEGAIoT_BusIO@1.0.0]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [EIS@0.0.1 Adafruit BusIO@1.17.2 EIS_INTERBOT@1.0.0 VEGAIoT_BusIO@1.0.0]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp -o /dev/null
Alternatives for SPI.h: [EventEthernet@1.0.0 SPI]
ResolveLibrary(SPI.h)
-> candidates: [EventEthernet@1.0.0 SPI]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/AdafruitIO.cpp -o /dev/null
Alternatives for Adafruit_MQTT.h: [LiveObjectsSDK@2.1.1 Adafruit MQTT Library@2.6.0]
ResolveLibrary(Adafruit_MQTT.h)
-> candidates: [LiveObjectsSDK@2.1.1 Adafruit MQTT Library@2.6.0]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/AdafruitIO.cpp -o /dev/null
Alternatives for ArduinoHttpClient.h: [ArduinoHttpClient@0.6.1]
ResolveLibrary(ArduinoHttpClient.h)
-> candidates: [ArduinoHttpClient@0.6.1]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/AdafruitIO.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/AdafruitIO_Dashboard.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/AdafruitIO_Data.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/AdafruitIO_Feed.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/AdafruitIO_Group.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/AdafruitIO_Time.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/blocks/AdafruitIO_Block.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/blocks/ChartBlock.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/blocks/GaugeBlock.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/blocks/MapBlock.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/blocks/MomentaryBlock.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/blocks/SliderBlock.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/blocks/StreamBlock.cpp -o /dev/null
This is the second half of the verbose text:
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/wifi/AdafruitIO_ESP32.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/wifi/AdafruitIO_ESP8266.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/wifi/AdafruitIO_MKR1000.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src/wifi/AdafruitIO_WICED.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src/Modem.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src/StringHelpers.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src/WiFi.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src/WiFiClient.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src/WiFiFileSystem.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src/WiFiSSLClient.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src/WiFiServer.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src/WiFiUdp.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire/Wire.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor/Adafruit_Sensor.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_BME280_Library/Adafruit_BME280.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_BusIO/Adafruit_BusIO_Register.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_BusIO/Adafruit_GenericDevice.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_BusIO/Adafruit_I2CDevice.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI/SPI.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library/Adafruit_MQTT.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library/Adafruit_MQTT_Client.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/ArduinoHttpClient/src/HttpClient.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/ArduinoHttpClient/src/URLEncoder.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/ArduinoHttpClient/src/WebSocketClient.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/ArduinoHttpClient/src/b64.cpp -o /dev/null
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/directories-user/libraries/ArduinoHttpClient/src/utility/URLParser/http_parser.c -o /dev/null
Generating function prototypes...
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp -o /tmp/2157882646/sketch_merged.cpp
/run/arduino/directories-data/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/2157882646/sketch_merged.cpp
Compiling sketch...
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"/var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/SensorSketch.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/Adafruit_IO_Arduino/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire -I/var/run/arduino/directories-user/libraries/Adafruit_Unified_Sensor -I/var/run/arduino/directories-user/libraries/Adafruit_BME280_Library -I/var/run/arduino/directories-user/libraries/Adafruit_BusIO -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI -I/var/run/arduino/directories-user/libraries/Adafruit_MQTT_Library -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp -o /var/run/arduino/user-cache/sketches/6EAF3DB85824D99B2BA5E8B57BA661AD/sketch/SensorSketch.ino.cpp.o
Using library Adafruit IO Arduino at version 4.3.2 in folder: /run/arduino/directories-data/internal/Adafruit_IO_Arduino_4.3.2_175ec4d29faa9de5
Using library WiFiS3 at version 0.0.0 in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/WiFiS3
Using library Wire in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire (legacy)
Using library Adafruit Unified Sensor at version 1.1.15 in folder: /run/arduino/directories-data/internal/Adafruit_Unified_Sensor_1.1.15_c4f0a59ad82fa17d
Using library Adafruit BME280 Library at version 2.3.0 in folder: /run/arduino/directories-data/internal/Adafruit_BME280_Library_2.3.0_b9f3bfd7860fc467
Using library Adafruit BusIO at version 1.17.2 in folder: /run/arduino/directories-data/internal/Adafruit_BusIO_1.17.2_a44a5fe9533d10ba
Using library SPI in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI (legacy)
Using library Adafruit MQTT Library at version 2.6.0 in folder: /run/arduino/directories-data/internal/Adafruit_MQTT_Library_2.6.0_36f7ae86bd19088e
Using library ArduinoHttpClient at version 0.6.1 in folder: /run/arduino/directories-data/internal/ArduinoHttpClient_0.6.1_969df906691206c8
/run/arduino/sketches/SensorSketch/SensorSketch.ino:35:1: error: 'AdafruitIO_WiFi' does not name a type; did you mean 'Adafruit_BME280'?
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
Adafruit_BME280
/run/arduino/sketches/SensorSketch/SensorSketch.ino:53:1: error: 'AdafruitIO_Feed' does not name a type; did you mean 'Adafruit_BME280'?
AdafruitIO_Feed *temperature = io.feed("temperature");
Adafruit_BME280
/run/arduino/sketches/SensorSketch/SensorSketch.ino:54:1: error: 'AdafruitIO_Feed' does not name a type; did you mean 'Adafruit_BME280'?
AdafruitIO_Feed *humidity = io.feed("humidity");
Adafruit_BME280
/run/arduino/sketches/SensorSketch/SensorSketch.ino:55:1: error: 'AdafruitIO_Feed' does not name a type; did you mean 'Adafruit_BME280'?
AdafruitIO_Feed *pressure = io.feed("pressure");
Adafruit_BME280
/run/arduino/sketches/SensorSketch/SensorSketch.ino: In function 'void setup()':
/run/arduino/sketches/SensorSketch/SensorSketch.ino:82:1: error: 'io' was not declared in this scope
io.connect();
/run/arduino/sketches/SensorSketch/SensorSketch.ino:83:22: error: 'AIO_CONNECTED' was not declared in this scope
while (io.status() < AIO_CONNECTED) { //in ohewr other words while NOT connected
/run/arduino/sketches/SensorSketch/SensorSketch.ino:83:22: note: suggested alternative: 'WL_CONNECTED'
WL_CONNECTED
/run/arduino/sketches/SensorSketch/SensorSketch.ino: In function 'void loop()':
/run/arduino/sketches/SensorSketch/SensorSketch.ino:101:3: error: 'io' was not declared in this scope
io.run();
/run/arduino/sketches/SensorSketch/SensorSketch.ino:111:1: error: 'temperature' was not declared in this scope
temperature->save(t);
/run/arduino/sketches/SensorSketch/SensorSketch.ino:112:1: error: 'humidity' was not declared in this scope
humidity->save(h);
/run/arduino/sketches/SensorSketch/SensorSketch.ino:112:1: note: suggested alternative: 'infinity'
humidity->save(h);
infinity
/run/arduino/sketches/SensorSketch/SensorSketch.ino:113:1: error: 'pressure' was not declared in this scope
pressure->save(p);
/run/arduino/sketches/SensorSketch/SensorSketch.ino:121:13: error: expected '}' at end of input
delay(20000);
Multiple libraries were found for "Wire.h"
Used: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/Wire
Not used: /run/arduino/directories-data/internal/FlexWire_1.2.1_1fc5f1d1a14af0e7
Multiple libraries were found for "Adafruit_Sensor.h"
Used: /run/arduino/directories-data/internal/Adafruit_Unified_Sensor_1.1.15_c4f0a59ad82fa17d
Not used: /run/arduino/directories-data/internal/ClimaStick_1.3.1_233fdd430f7c3408
Multiple libraries were found for "Adafruit_I2CDevice.h"
Used: /run/arduino/directories-data/internal/Adafruit_BusIO_1.17.2_a44a5fe9533d10ba
Not used: /run/arduino/directories-data/internal/EIS_0.0.1_7b9a78c117637fbc
Not used: /run/arduino/directories-data/internal/EIS_INTERBOT_1.0.0_4c1ce07692fbb2fd
Not used: /run/arduino/directories-data/internal/VEGAIoT_BusIO_1.0.0_68606b9abaf94dc3
Multiple libraries were found for "SPI.h"
Used: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.5.0/libraries/SPI
Not used: /run/arduino/directories-data/internal/EventEthernet_1.0.0_bd9dd894ef7641f8
Multiple libraries were found for "Adafruit_MQTT.h"
Used: /run/arduino/directories-data/internal/Adafruit_MQTT_Library_2.6.0_36f7ae86bd19088e
Not used: /run/arduino/directories-data/internal/LiveObjectsSDK_2.1.1_f840720f4815981c
I want to point something out that I think is important.
Even if use an "example" sketch in the IDE for adafruit io arduino, it still stops compleing at the same line:
The short message is always the same:
Compilation error: 'AdafruitIO_WiFi' does not name a type
All the AI assistants tell me that this means the Library "Adafruit IO Arduino" is not installed but when i go to install it, it states that it is laready installed. I have removing it then rfeinstalling. I have installed from the IDE. I have installed it from Github. Bit nothing works.
Many thanks
steve9
August 24, 2025, 7:10am
6
The AI's interpretation of the problem as being caused by the library installation is incorrect. The library is installed just fine. The problem is that, unfortunately, the "Adafruit IO Arduino " library does not have support for the WiFiS3 library of the UNO R4 WiFi board.
I see a related discussion on the Adafruit Forum:
https://forums.adafruit.com/viewtopic.php?p=1040156&sid=586334334cbdc46976d578e919a116f3#p1040156
Our Arduino libraries for Adafruit IO is here:
https://github.com/adafruit/Adafruit_IO_Arduino
https://github.com/brentru/Adafruit_MQTT_Library
and the Adafruit IO API documentation is here:
https://github.com/adafruit/Adafruit_IO_Documentation
We don't carry the Arduino R4 Wifi or target code specifically to it, but the protocols use basic HTTP and MQTT messages. At worst, you should be able to port the code over without too much work.
https://forums.adafruit.com/viewtopic.php?p=1040504&sid=586334334cbdc46976d578e919a116f3#p1040504
I've got it connected to Adafruit IO using MQTT.
So I think the idea is that you should use "Adafruit MQTT Library " directly in your sketch rather than using the Adafruit IO Arduino library. Adafruit MQTT Library has a flexible interface that allows it to be used with any networking library that produces that standard Arduino Client object. The WiFiS3 library, so you only need to use the WiFiS3 library to create a Client object, then pass that object to the Adafruit MQTT Library code to communicate with the Adafruit IO service.
thanks so much, yes this worked. Appreciate your time!!
