Hello!
I have very big problem, I can't programm boot code using uisp! I have tried many things, changed seetings in BIOS, installed giveio, tryed diffrent sch for ISP like http://www.ncfreak.com/cecilia/elec/usbavrw/sch/dapa.pdf and http://arduino.berlios.de/index.php/Main/ParallelProgrammer tryed in linux nothing works. For programming i use this batch
cd .. tools\avr\bin\uisp -dpart=ATmega8 -dprog=dapa -dlpt=0x378 --download of=log.txt tools\avr\bin\uisp -dpart=ATmega8 -dprog=dapa -dlpt=0x378 --wr_lock=0xFF tools\avr\bin\uisp -dpart=ATmega8 -dprog=dapa -dlpt=0x378 --wr_fuse_l=0xdf --wr_fuse_h=0xca pause tools\avr\bin\uisp -dpart=ATmega8 -dprog=dapa -dlpt=0x378 --erase pause tools\avr\bin\uisp -dpart=ATmega8 -dprog=dapa -dlpt=0x378 --upload if=bootloader\ATMegaBOOT.hex pause tools\avr\bin\uisp -dpart=ATmega8 -dprog=dapa -dlpt=0x378 --verify if=bootloader\ATMegaBOOT.hex pause tools\avr\bin\uisp -dpart=ATmega8 -dprog=dapa -dlpt=0x378 --wr_lock=0xCF cd bootloader pause
and this is what I get out
20:18:03,10 - XPize
E:\arduino\arduino-0003\bootloade
E:\arduino\arduino-0003|> tools\a x378 --download of=log.txt Atmel AVR ATmega8 is found. Downloading: flash
S0080000666C617368E9 S1130000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC S1130010FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC S1130020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC S1130030FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC S1130040FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC ..... and so on S5030200FA S9030000FC
E:\arduino\arduino-0003|> tools\a x378 --wr_lock=0xFF Atmel AVR ATmega8 is found. Writing lock bits ... Reinitializing device Atmel AVR ATmega8 is found.
Lock Bits set to 0xff
E:\arduino\arduino-0003|> tools\a x378 --wr_fuse_l=0xdf --wr_fuse_h= Atmel AVR ATmega8 is found.
Fuse Low Byte set to 0xdf
Fuse High Byte set to 0xca
E:\arduino\arduino-0003|> pause
E:\arduino\arduino-0003|> tools\avr\bin\uisp -dpart=ATmega8 -dprog=dapa -dlpt=0 x378 --erase Atmel AVR ATmega8 is found. Erasing device ... Reinitializing device Atmel AVR ATmega8 is found.
E:\arduino\arduino-0003|> tools\ x378 --upload if=bootloader\ATMeg Atmel AVR ATmega8 is found. Uploading: flash
flash error at address 0x1ece: file=0x10, mem=0xff flash error at address 0x1ecf: file=0x32, mem=0xff flash error at address 0x1ed0: file=0x58, mem=0xff flash error at address 0x1ed1: file=0xf0, mem=0xff ... and so on
E:\arduino\arduino-0003|> tools\avr\bin\uisp -dpart=ATmega8 -dprog=dapa -dlpt=0 x378 --wr_lock=0xCF Atmel AVR ATmega8 is found. Writing lock bits ... Reinitializing device Atmel AVR ATmega8 is found. Warning: lock bits write=0xCF read=0xFF
Lock Bits set to 0xcf
E:\arduino\arduino-0003|> cd bootloader
E:\arduino\arduino-0003\bootloader|> pause
I'am using Serial version of Arduino board v2.0s. I have discoverd that when i connect isp header on lpt port but no power to the board the power led slightly lights and led betwen output 13 and gnd is blinking while programming!
PLEASE HELP!
