Can't receive and transmit data on xbee
So I am creating a 2 project simulation using proteus and Arduino ide. A controller and the device. What I am trying to do is to transmit and received a string to the controller and device. When I did a one-way communication, it works fine. However, if I did a 2-way it doesn't work. I have tried all sorts of ways in what I am capable of but I'm still having a hard time solving the problem any suggestions. I tried using the software serial along with the hardware serial but it still doesn't work Here's what I have so far sorry if it's a bit messy. Any help would be appreciated. Thanks.
I am using the Atmega328P microcontroller. But I am making it behave like an arduino uno
I wrote the code here in the post and included in the attachment
I also included in the attachment the simulation circuit for the device and controller
REMOTE:
* TestingRemote_5
#include <SoftwareSerial.h>
#include <Servo.h>
SoftwareSerial extra(2,3); //RX,TX
//joystick
int X = A0;
int Y = A1;
int servopin=6;
Servo servo1;
//Variables for servo and motor control
int servoctrl;
int motorctrl;
//sending
char motor;
char servo;
char sw='1';
//receiving
const byte numchars = 3;
char rccvd[numchars];
char temprccvd[numchars];
float batt=0.0;
//checking
//int batt1[numchars]={'H','M','L'};
bool newdata = false;
Serial.begin(9600); //XBEE
extra.begin(9600);  //For ////debugging purposes
//debug.println("REMOTE DEBUG");
pinMode(X,INPUT);
pinMode(Y,INPUT);
servo1.attach(servopin);
joystick();
senddata();
rccvdchars();
if (newdata == true)
 strcpy(temprccvd,rccvd);
 parsedata();
 //battery();
 //debugdata();
 newdata = false;
void rccvdchars()
 char start = '<';
 char ended = '>';
 static byte index = 0;
 char data;
 static bool inProg = false;
 while (extra.available() >= 0)
   data = extra.read();
    if (inProg == true)
     //debug.println("Start");
     if ( data != ended)
       rccvd[index] = data;
       index++;
       if ( index >= numchars)
         index = numchars - 1;
       //debug.println("data == ended");
       rccvd[index] = '\0';
       inProg = false;
       index = 0;
       newdata = true;
   else if ( data == start)
     //debug.println("data==start");
     inProg = true;
void joystick()
 motorctrl = analogRead(X);
 servoctrl = analogRead(Y);
 motorctrl >>= 1;
 if ( motorctrl > 230 && motorctrl < 276)
   motor = 'N';
 else if ( motorctrl < 255)
   motor = 'B';
 else if ( motorctrl > 255)
   motor = 'F';
 if ( servoctrl >= 461 && servoctrl <= 553) //center
   servo = 'C';
   servo1.write(180);
 else if (servoctrl < 451) //left
   servo1.write(68);
   servo = 'L';
 else if (servoctrl > 563 ) //right
   servo = 'R';
   servo1.write(117);
void parsedata()
 char *ptr;
 ptr = strtok(temprccvd,";");
 batt = atof(ptr);
 ptr = strtok(NULL,";");
void senddata()
 Serial.println((String)"<"+motor+";"+servo+";"+sw+">");
 delay(15);
void debugdata()
//  debug.println((String)"<"+motor+";"+servo+";"+sw+">");
 delay(100);
void battery()
// debug.println(batt);
 delay(100);
Here's the Device Code:
* DeviceTesting_5
#include <Servo.h>
//motors
int in1 = 10;
int in2 = 11;
int in3 = 4;
int in4 = 5;
int servopin = 6;
int pos1 = 0;
int pos2 =0;
Servo servo;
//receving
const byte numchars = 7;
char motor[numchars]={0};
char smotor[numchars]={0};
char sw[numchars]={0};
//checking
int chkt = 0;
int pos = 0;
char motor1[numchars]={'F','B','N'};
char smotor1[numchars]={'L','R','C'};
char sw1[numchars]={'H','O'};
//sending
char batts;
//other variables
float batt = A0;
float V;
 extra.begin(9600);
 //debug.begin(9600);
 //debug.println("DEVICE //debug");
 pinMode(in1,OUTPUT);
 pinMode(in2,OUTPUT);
 pinMode(in3,OUTPUT);
 pinMode(in4,OUTPUT);
 pinMode(batt,INPUT);
 servo.attach(servopin);
 senddata();
 rccvdchars();
   parsedata();
   //debugdata();
   newdata = false;
  chkt = check();
  if (chkt == 2)
   movemotors();
   pos2 = servomo();
   servo.write(pos2);
   //delay(15);
void senddata()
 extra.println((String)"<"+V+">");
 //delay(15);
void battery()
 float val = analogRead(batt);
 V = val*(5/1023.00)*2;
int servomo()
 if (smotor[0] == smotor1[0])
   pos1 = 50;
 else if (smotor[0] == smotor1[1])
   pos1 = 100;
 else if (smotor[0] == smotor1[2])
   pos1 = 90;
 return(pos1);
void rccvdchars()
 char start = '<';
 char ended = '>';
 char data;
 int A =9;
 while (Serial.available() > 0)
   data = Serial.read();
    if (inProg == true)
     ////debug.println("Start");
     if ( data != ended)
       index++;
       ////debug.println("data == ended");
       inProg = false;
       index = 0;
       newdata = true;
     ////debug.println("data==start");
     inProg = true;
void parsedata()
 char *ptr;
 strcpy(motor,ptr);
 strcpy(smotor,ptr);
 strcpy(sw,ptr);
void debugdata()
 //debug.print("Motor(NON):");
 //debug.println(motor[0]);
 //debug.print("Servo(NON):");
 //debug.println(smotor[0]);
 //delay(1000);
 /*//debug.print("Switch:");
 //debug.println(sw);*/
void movemotors()
 if (motor[0] == motor1[0])
   digitalWrite(in1,LOW);
   digitalWrite(in2,HIGH);
   digitalWrite(in3,LOW);
   digitalWrite(in4,HIGH);
 else if (motor[0] == motor1[1])
   digitalWrite(in1,HIGH);
   digitalWrite(in2,LOW);
   digitalWrite(in3,HIGH);
   digitalWrite(in4,LOW);
int check()
 int total,chk1=0,chk2=0;
   chk1 = chk1 + 1;
   chk1 = chk1 + 1;
 if (motor[0] == motor1[2])
   chk1 = chk1 + 1;
   chk2 = chk2 + 1;
   chk2 = chk2 + 1;
   chk2 = chk2+ 1;
 //debug.print("TOTAL:");
 total = chk1 + chk2;
 //debug.println(total);
 return (total);
TestingRemote_5.ino (2.54 KB)
DeviceTesting_5.ino (3.74 KB)
Read the how to use this forum-please read sticky to see how to properly post code. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code. If the code is too large to post it can be attached.
Edit your original post to conform to the guidelines, please.
Read this before posting a programming question.
What Arduino boards are you using?
How are the boards connected? Schematic please.
