Dear Sir
Sir,
I've just found some problem when i use Arduino uno r3 for getting data from another micro
it cant receive all data (just 64byte i got) ,actually another micro is going to send data 512byte
when it receive some ascii from Arduino
a....please help me to sovle this problem
b....how can i receive data morethan 64bytes by arduino
thank you
Post your code.
But it sounds like you are filling the receive buffer (which quite by chance is 64 bytes in size) and not clearing the data in time so the remaining bytes are discarded.
Rob
can you help me how to do to receive data morethan 64bytes
Sittipong:
yes.
post what code you have.
Sittipong:
Dear Sir
You there in the front row. You have a question?
I'm guessing:
Look at the HardwareSerial.h header file found in your IDE directory:
hardware\arduino\avr\cores\arduino
and you will see that the transmit and receive buffers are set to 64 bytes.
Does this give you any ideas? While running the Serial monitor, type in 80 characters (or so) and click Send.
int bytesRead;
char buff[101];
if (Serial.available() > 0) {
bytesRead = Serial.readBytesUntil('\n', buff, 100);
buff[bytesRead] = '\0';
Serial.print("bytesRead = ");
Serial.println(bytesRead);
Serial.print("buff = ");
Serial.println(buff);
i just send ascii N to another micro to active command
if another micro got ascii N it will send data 512bytes back to arduino
but..i've just receive only 64bytes
This is my code
char asciiN(char N)
unsigned char RevBuffer[512];
unsigned int Lenght;
lcd.clear();
lcd.setCursor(0,1);
lcd.print (" send Ascii N.");
delay(200);
lcd.setCursor(0,1);
lcd.print (" send Ascii N...");
Serial.write(N);
delay(200);
if(Serial.available())
//wait for serial buffer to fill itself
Lenght=Serial.available();
Serial.readBytes(RevBuffer,Lenght);
Serial.setTimeout(1000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print ("Lenght.... ");
lcd.print (Lenght);
for(int i=0;i<Lenght;i++)
lcd.clear();
lcd.setCursor(0,0);
lcd.print ("Data :");
lcd.setCursor(6,0);
lcd.print (i);
lcd.setCursor(0,1);
lcd.print ("HEX :0x");
lcd.print (RevBuffer[i],HEX);
lcd.clear();
lcd.setCursor(0,0);
lcd.print ("nothing Return..");
The serial buffer is 64 bytes. Don't do it this way.
can you give me any idea to get data more
try reading the link that Nick posted...
i have question for Arduino Uno programming
can we change serial buffer from 64bytes to 512bytes? or more
a.....if can, how to do
b......if cannot ,there is another way to get data more
PS. i heard that we have to change in HardwareSerial.h ......But how to change
Thank you for your answer ![]()
If you change the size of the serial buffer change it down not up 64 is far far to big. The simple way to deal with incoming data is to read it. Get rid of all those delay's your using.
Mark
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
I think this is the third thread you have started on this question. Don't ignore the answers and start a new thread. If you keep doing it your account will be deleted.
Did you not understand my previous reply?
- Moderator
