I'm trying to send UDP data to specific addresses to avoid broadcast flooding in the local network, but unfortunately only the global broadcast address 255.255.255.255 works!
In the program bellow there are three types of addresses, and only the third one is received.
The destination machine has a manually set ip, and I'm able to ping it on 192.168.31.22!
This is the code:
#include <EtherCard.h>
// Network settings
byte mymac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; // MAC address
byte myip[] = {192, 168, 31, 100}; // Arduino IP
const uint16_t PORT = 5005; // UDP port
// Ethernet buffer
byte Ethernet::buffer[500]; // This is the crucial missing piece!
Serial.println("\n");
// Initialize Ethernet (CS pin = 10 for Uno)
if (!ether.begin(sizeof(Ethernet::buffer), mymac, 10)) {
Serial.println("Failed to initialize ENC28J60!");
while(1);
// Set static IP (disable DHCP)
ether.staticSetup(myip);
Serial.println("Ethernet initialized");
// 1. DOESN'T WORK :(
const char* data_specific = "1. Single Address!";
const byte single_ip[] = {192, 168, 31, 22}; // Single destination IP
delay(2000); // Send every 2 seconds
Serial.println(data_specific);
ether.sendUdp(
data_specific, // Payload
strlen(data_specific), // Length
PORT, // Source port
single_ip, // Destination IP
PORT // Destination port
// 2. DOESN'T WORK :(
const char* data_network = "2. Network Address!";
const byte network_ip[] = {192, 168, 31, 255}; // Network destination IP (broadcast)
Serial.println(data_network);
ether.sendUdp(
data_network, // Payload
strlen(data_network), // Length
network_ip, // Destination IP
// 3. IT WORKS :)
const char* data_global = "3. Global Address!";
const byte global_ip[] = {255, 255, 255, 255}; // Global destination IP (broadcast)
Serial.println(data_global);
ether.sendUdp(
data_global, // Payload
strlen(data_global), // Length
global_ip, // Destination IP
Thanks.
