I am brand-new to all this. I have the following error when trying to upload the Blink example to my Nano:
avrdude: stk500_getsync(): not in sync: resp=0x00
So i have vista 64-bit. the driver installed correctly as far as i am aware
i have the correct board selected (Nano w/ ATmega328) and correct port selected (COM3).
physically, the PWR led is constantly on and the L led is flashing on/off.
when i click Upload, the L led rapidly flashes 3 times and then the RX led does 3 small flashes, and then the L led goes back to the constant flashing, and then i get the above error.
i tried pressing the reset button at different points for different time intervals, but no luck.
Are you running Arduino 1.0 or older one ?
Verbose output could show more
on older Arduino software just hold shift while uploading
and on Arduino 1.0 go to file -> preferences -> show verbose output
I feel some sympathy because this happened to me yesterday with a Uno that had previously worked. Turned out I must have done something to the bootloader (not too surprising with what goes on here). That doesn't particularly help you, but if you have another programmer or an Arduino Uno you can set up as ArduinoISP, you might be able to work out a bit more. The verbose output might give a clue.
When you connect/disconnect the Nano does Windows do that USB 'bing-bong' sound?
All my Nanos come in at > COM10.
Once, I bought some that came with bad cables.
ok, so i tried connecting the nano to my laptop which is running XP and it works!! was able to successfully upload the blink example.
hmmm, maybe it is a driver issue or some other software conflict issue with my vista desktop?
well, i dont care, as long as it is working on the laptop, im happy to just work with it off that and not spend any more time troubleshooting.
thanks to all who provided their time of day to try to help me out. im sure ill be having lots of frustrating (but fun) moments which will require me to seek help here, but it seems people are genuinely helpful!
