Gate6
July 25, 2018, 6:18am
1
Hi.
I am korean. and beginner.
I am programming with Capacitive Sensor Library at Uno board , but it is showing the sensor capacitive values on the serial terminal is very slow.
One sensor code, Response time is 2 millions sec
Two sensor code, Response time is 1.5 sec.
Three sensor code, Response time is 3sec
How can i fix to slow problem..
DIY_Piano.ino (4.51 KB)
system
July 25, 2018, 8:09am
2
if (total1<=150 & total2<=150 & total3<=150 & total4<=150 & total5<=150 & total6<=150 & total7<=150)
& and && are two different operators. One is correct in this context. One is not. You chose the wrong one.
Use micros() and time how long ONE call to the capacitiveSensor() method takes. Then, figure out how long 7 calls take.
Gate6
July 25, 2018, 8:30am
3
I think problem form this code
long total1 = cs_2_3.capacitiveSensor(30);
long total2 = cs_2_4.capacitiveSensor(30);
long total3 = cs_2_5.capacitiveSensor(30);
long total4 = cs_2_6.capacitiveSensor(30);
long total5 = cs_2_7.capacitiveSensor(30);
long total6 = cs_2_8.capacitiveSensor(30);
long total7 = cs_2_9.capacitiveSensor(30);
when i use just one line. Response is very fast . like 2 millions sec
Start by simplifying the code. Remove all the crap not needed for the problem.
Also show both examples of the 1 and multiple sensor setups. And post them like you're supposed to. Have a look at How to use the forum.
Some extra notes:
CapacitiveSensor cs_2_4 = CapacitiveSensor(2,4); // 10M resistor between pins 4 & 6, pin 6 is sensor pin, add a wire and or foil
Wrong comments are worse than no comments
And if you start numbering variables, arrays are the answer
