I have the following capacitive soil sensor.
const int AirValue = 520; //you need to replace this value with Value_1
const int WaterValue = 260; //you need to replace this value with Value_2
int intervals = (AirValue - WaterValue)/3;
int soilMoistureValue = 0;
Serial.begin(9600); // open serial port, set the baud rate to 9600 bps
soilMoistureValue = analogRead(A0); //put Sensor insert into soil
if(soilMoistureValue > WaterValue && soilMoistureValue < (WaterValue + intervals))
Serial.println("Very Wet");
else if(soilMoistureValue > (WaterValue + intervals) && soilMoistureValue < (AirValue - intervals))
Serial.println("Wet");
else if(soilMoistureValue < AirValue && soilMoistureValue > (AirValue - intervals))
Serial.println("Dry");
delay(100);
Basically we need to calibrate the sensor by entering the dry and wet value, which is done by analogRead. Pardon my math, but I have trouble understanding the following
Could someone explain the above equation. Why do we have to deduct, then divide by 3?
