#include <LiquidCrystal.h>
#define THRES 30
#define SAMPLES 15
//#define SERIAL_DEBUG
#define LED1 6
#define LED2 7
#define LED3 8
#define LED4 9
typedef struct touchPad{
int pin;
int unpValue;
int value;
char state=0, prevState=0;
char toggleState=0;
touchPad touchPad1, touchPad2, touchPad3, touchPad4;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
/* Set A0 pull-up resistor, used to charge internal capacitor */
pinMode(A0, INPUT_PULLUP);
analogRead(A0);
//lcd
lcd.begin(16, 2);
lcd.print("start load.......");
pinMode(LED1, OUTPUT);
digitalWrite(LED1, 0);
pinMode(LED2, OUTPUT);
digitalWrite(LED2, 0);
pinMode(LED3, OUTPUT);
digitalWrite(LED3, 0);
pinMode(LED4, OUTPUT);
digitalWrite(LED4, 0);
/* Initialize sensors */
touchPadInit(&touchPad1, A1);
touchPadInit(&touchPad2, A2);
touchPadInit(&touchPad3, A3);
touchPadInit(&touchPad4, A4);
#ifdef SERIAL_DEBUG
Serial.begin(57600);
#endif
/* Scan sensors */
touchPadScan(&touchPad1);
touchPadScan(&touchPad2);
touchPadScan(&touchPad3);
touchPadScan(&touchPad4);
/* Use sensors reding to control LEDs */
digitalWrite(LED1, touchPad1.toggleState);
digitalWrite(LED2, touchPad2.toggleState);
digitalWrite(LED3, touchPad3.toggleState);
digitalWrite(LED4, touchPad4.toggleState);
delay(10);
#ifdef SERIAL_DEBUG
Serial.print(touchPad1.value);
Serial.print(",");
Serial.print(touchPad2.value);
Serial.print(",");
Serial.print(touchPad3.value);
Serial.print(",");
Serial.println(touchPad4.value);
#endif
void touchPadInit(touchPad *pad, int pin){
pad->pin=pin;
pad->unpValue = (sampleB(pin) - sampleA(pin));
DIDR0 |= 1;
DIDR0 |= 1<<(pin-A0);
int sampleA(int sensePin){
/* Sample capacitor is charged to VCC
* via A0 pull-up resistor, touch pad
* is discharged by pulling pin low
ADMUX = 0b01000000;
pinMode(sensePin, OUTPUT);
digitalWrite(sensePin, 0);
pinMode(sensePin, INPUT);
ADMUX = 0b01000000 | sensePin-A0;
ADCSRA |= 1<<ADSC;
while((ADCSRA & (1<<ADSC)) != 0);
return ADC;
int sampleB(int sensePin){
/* Sample capacitor is discharged by selecting
* GND as ADC input, touch pad is charged to VCC
* via pin pull-up resistor
ADMUX = 0b01001111;
pinMode(sensePin, INPUT_PULLUP);
ADCSRA |= 1<<ADSC;
return ADC;
void touchPadScan(touchPad *pad){
static float A, B;
A=0;
B=0;
/* Get some readings from sensor and calculate average */
for(int i=0; i<SAMPLES; i++){
A += sampleA(pad->pin);
B += sampleB(pad->pin);
A /= SAMPLES;
B /= SAMPLES;
pad->value = (B - A);
/* Member unpValue is a running average of the unpressed readings.
* A sudden change in sensor reading is interpreted as a touch
if(pad->value > (pad->unpValue + THRES))
pad->state=1;
else{
pad->state=0;
pad->unpValue=((float)pad->unpValue*0.9)+((float)pad->value*0.1);
if(pad->state == 1 && pad->prevState == 0)
pad->toggleState = !pad->toggleState;
pad->prevState = pad->state;
dit is mijn code wat ik al een heel eind heb gemaakt maar nu lukt het noch niet om op een lcd 16, 2 te zetten welke LED er aanstaat das als ik LED1 aan zet wil ik dat op mijn lcd zien
zou iemand mij daar bij kunnen helpen alvast bedankt
