mrnams
January 2, 2024, 7:02pm
1
Hello All,
I have written program which takes user input for turning on/off water pump.
Here is program,
int localPumpSwitchValue = 0;
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
ReconnectWiFiRefreshFirebaseToken();
ReadLocalSwitchValueAndSaveToFirebase();
LoadFirebaseToLocalSwitchValue();
SendCommandsToNodes();
if ( (millis() - fireBaseObj.m_sendDataPrevMillis) > userSettings.m_intervalToUploadSensorDataToFirebase || fireBaseObj.m_sendDataPrevMillis == 0))
fireBaseObj.m_sendDataPrevMillis = millis();
fireBaseObj.SaveSensorDataToFireBase(sensorData);
void ReadLocalSwitchValueAndSaveToFirebase()
if (digitalRead(4) == LOW)
localPumpSwitchValue = 1;
if (digitalRead(5) == LOW)
My problem is when user press button to turn on/of pump, then at that time code is executing some other functions like saving datat to firebase or receiving data from LoRa, so user input get lost, work around i use is, i keep button pressed until input is read by programm.
So how to make user input real time?
mikb55
January 3, 2024, 1:11am
2
Your picture shows an ESP8266. Is that what you have?
If so, use a RTOS task to sample the pins at 30 millisecond intervals and feed the resulting data into a debounce algorithm.
If you are using a non-RTOS system then use a timer interrupt to do the same thing.
Alternatively use an external SR flip flop chip to latch the button states.
mrnams
January 3, 2024, 2:55am
3
Many thanks.
I am new to these concepts, could you please explain more with sample code.
Or just share material link to study it.
horace
January 3, 2024, 9:15am
4
attach an interrupt to your button inputs so when a button is pressed an interrupt routine is called and takes appropriate action, e.g. handling-esp8266-gpio-interrupts-tutorial
J-M-L
January 3, 2024, 9:29am
5
your code is not complete
what type of switch do you have ? is it bouncing ?
the code you show does not do anything with localPumpSwitchValue
side note:
you use 4 and 5 for the pins
and you are connected to D1 and D2
On a typical ESP8266 that would be OK
but it's usually better to use D1 and D2 in the pin related functions to ensure you don't have a mismatch there
mrnams
January 3, 2024, 3:41pm
7
method use localPumpSwitchValue
variable to send its value to lora node.
Yes switches are bouncing
mrnams
January 3, 2024, 3:53pm
8
@horace Thanks, any limit to declare interrupt, or we can declare more than 1 interupts
horace
January 3, 2024, 7:09pm
9
you can have more than one GPIO interrupt enabled
the ESP8266 Pinout Reference: Which GPIO pins should you use? states
The ESP8266 supports interrupts in any GPIO, except GPIO16.
e.g.
volatile int isr5Change=-1;
void IRAM_ATTR isr5() {
isr5Change=digitalRead(5);
volatile int isr4Change=-1;
void IRAM_ATTR isr4() {
isr4Change=digitalRead(4);
volatile int isr14Change=-1;
void IRAM_ATTR isr14() {
isr14Change=digitalRead(14);
delay(3000);
Serial.printf("\n\nESP8266 GPIO interrupt test");
attachInterrupt(5, isr5, CHANGE);
attachInterrupt(4, isr4, CHANGE);
pinMode(14, INPUT_PULLUP);
attachInterrupt(14, isr14, CHANGE);
if(isr5Change>=0) {
Serial.printf("GPIO5 change %d\n", isr5Change);
isr5Change=-1;
if(isr4Change>=0) {
Serial.printf("GPIO4 change %d\n", isr4Change);
isr4Change=-1;
if(isr14Change>=0) {
Serial.printf("GPIO14 change %d\n", isr14Change);
isr14Change=-1;
serial monitor displays
ESP8266 GPIO interrupt testGPIO5 change 0
GPIO5 change 1
GPIO5 change 1
GPIO5 change 0
GPIO5 change 0
GPIO5 change 1
GPIO4 change 0
GPIO4 change 1
GPIO4 change 0
GPIO4 change 1
GPIO4 change 0
GPIO4 change 0
GPIO4 change 1
GPIO14 change 0
GPIO14 change 1
GPIO14 change 0
GPIO14 change 0
GPIO14 change 0
GPIO14 change 1
I was plugging/unpluging a jumper wire between the GPIO pins and GND
clearly getting the effect of switch bounce
mrnams
January 4, 2024, 3:54am
10
Thanks, so this is enough and no need to go for free RTOS right? or free RTOS worth studying and implementing?
horace
January 4, 2024, 8:34am
11
don't think you require aan RTOS for such a simple control system
updated GPIO interrupt test removing switch bounce
// ESP8266 GPIO interrupts - switch bounce removed
// GPIO is pulled up
// - on grounding pin 0 is displayed on pin high 1 is displayed
// on GPIO interrupt setup timer to remove switch bounce
volatile unsigned long isr5Change = 0;
static unsigned long timer=0;
if(millis()-timer<10) return; // ingore interrupts for a time
isr5Change= timer = millis(); // note interrupt time
volatile unsigned long isr4Change = 0;
isr4Change= timer = millis(); // note interrupt time
delay(3000);
Serial.printf("\n\nESP8266 GPIO interrupt test\n");
// set GPIO pullup and enable interrupts
// on interrupt wait a few mSec for level to stablise then display level
if(isr5Change && millis()-isr5Change > 2) {
Serial.printf("GPIO5 change %d\n", digitalRead(5));
isr5Change = 0; // clear the timer
if(isr4Change && millis()-isr4Change > 2) {
Serial.printf("GPIO4 change %d\n", digitalRead(4));
isr4Change = 0; // clear the timer
as I press a switch to ground the GPIO and then release it the serial monitor displays
GPIO5 change 0
GPIO5 change 1
GPIO5 change 0
GPIO5 change 1
GPIO5 change 0
GPIO5 change 1
GPIO5 change 0
GPIO5 change 1
GPIO4 change 0
GPIO4 change 1
GPIO4 change 0
GPIO4 change 1
system
Closed
July 2, 2024, 8:34am
12
