Hi! I have a quick question. I have this code that I got from Arduino RFID Motor Stepper V2 - YouTube, and I'm trying to implement it with my arduino mega. The code that they gave doesn't seem to have a clear place for me to put the Valid UID for the RFID Tag. Could someone please help?
Here is the code:
* RFID stepper motor control
* By James "Nadrew" Smith
* Elegoo Mega 2560 R3
* MB102 Power Supply
* Connect to stepper controller 5v.
* RFID (RC522) scanner, and MIFARE tags.
* REMINDER: The scanner is a 3.3v device, don't connect it to 5v!
* PINS:
* RST = 5 (must be PWM)
* IRQ = NA
* MISO = 50
* MOSI = 51
* SCK = 52
* SDA = 53
* A stepper motor and controller.
* PINS:
* IN1 = 8
* IN2 = 9
* IN3 = 10
* IN3 = 11
* A basic passive buzzer/speaker
* Connected to pin 6 (must be PWM)
* A RGB LED
* PINS: (all PWM)
* R = 2
* G = 3
* B = 4
#include <SPI.h>
#include <MFRC522.h>
#include <Stepper.h>
#define readerRST 5 // This is the RST pin on your RFID reader.
#define readerSS 53 // And this is the SS pin on the RFID reader.
#define stepperIN1 8
#define stepperIN2 9
#define stepperIN3 10
#define stepperIN4 11
// The three pins for the RGB LED output.
#define ledR 2
#define ledG 3
#define ledB 4
// The positive pin on your passive speaker.
#define speakerPin 6
#define STATUS_OK MFRC522::STATUS_OK
// How bright your RGB LED is.
#define color_intensity 50
MFRC522 mfrc522(readerSS, readerRST); // Create MFRC522 object for the card reader.
Stepper stepper(32,stepperIN1,stepperIN3,stepperIN2,stepperIN4);
void SetLed(int red,int green, int blue){
// Sets the colors of the RGB LED.
analogWrite(ledR,red);
analogWrite(ledG,green);
analogWrite(ledB,blue);
// Set our RGB LED pins to OUTPUT.
pinMode(ledR,OUTPUT);
pinMode(ledG,OUTPUT);
pinMode(ledB,OUTPUT);
// card reader init
SPI.begin(); // Initialize SPI
mfrc522.PCD_Init(); // Initialize the reader.
mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max); // Maximize the reader's antenna gain.
SetLed(0,0,color_intensity);
Serial.println("Waiting for card...");
void Authenticated() {
// This is called when a valid ID is read.
Serial.println("Auth passed");
// Play a quick 'good job!' tone.
tone(speakerPin,2500,50);
// Set the LED to green and start the motor.
SetLed(0,color_intensity,0);
stepper.setSpeed(500);
stepper.step(-580);
// Wait and step it back and set the LED back to blue.
delay(4000);
stepper.step(580);
void Failed() {
// Called when an invalid password is read.
Serial.println("Auth failed");
// A bad tone, baaaad.
tone(speakerPin,300,350);
// Flash the LED red a couple times.
SetLed(0,0,0);
delay(100);
SetLed(color_intensity,0,0);
delay(100);
SetLed(0,0,0);
delay(100);
delay(100);
// And back to blue.
// Look for new cards
// This is your MIFARE key, by default it's set to FFFFFFFFFFFF, but if you've changed it, you'll need to do that here.
// Otherwise your card will fail to read.
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
byte block, len;
MFRC522::StatusCode status;
if ( ! mfrc522.PICC_IsNewCardPresent()) {
// No reason to go further if there's no card detected.
// Or the same card is detected without being removed.
return;
if ( ! mfrc522.PICC_ReadCardSerial()) {
// Bail out if it can't read the card for whatever reason.
return;
Serial.println("Card detected, scanning...");
// I'm storing the passcode (18 bytes) in block 4 of the card.
// Ideally, this would be spread across the card and encoded somehow.
byte passcode[18];
block = 4;
len = 18;
String code_found;
// Authenticate the card with your key, and proceed if you get an OK, you can add error checking here if you want.
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 4, &key, &(mfrc522.uid));
if(status == STATUS_OK) {
// The authentication was good, so lets try to read the bytes from the block.
status = mfrc522.MIFARE_Read(block,passcode,&len);
// If the read is good, loop from 0 to 16 and build a string out of each byte in the block
for (uint8_t i = 0; i < 16; i++) {
if(!passcode[i] != 32) {
code_found += (char) passcode[i];
code_found.trim(); // Cut any fat here.
if(code_found == "VALID") {
// If the code is valid, we authenticate and run the motor, this should be turned into something properly secure, of course.
Authenticated();
else {
// If not, fail.
Failed();
// Now that everything is done, we're ready to shut the stepper control down, and wait for the next card.
// No cards can be read until this part of the code is reached.
delay(50);
digitalWrite(11,LOW);
digitalWrite(10,LOW);
digitalWrite(9,LOW);
digitalWrite(8,LOW);
mfrc522.PICC_HaltA();
mfrc522.PCD_StopCrypto1();
