Carrera Lap Timer (Arduino + 16x2 LCD, Serial Data)
Hi everyone,
I built a simple lap timing system for a Carrera racing track using an Arduino and a 16x2 LCD. It reads serial data from the Carrera Control Unit (PC UNIT port) and calculates lap times for two cars in real time.
Features:
  • Real-time lap timing (2 cars)
  • Best lap tracking
  • LCD output (16x2)
  • Visual indicator for fastest lap (custom character)
How it works:
The Arduino listens to serial data (19200 baud) from the Control Unit.
When a car crosses the sensor, a data packet is received.
The code parses the packet and calculates lap time using millis().
Hardware:
  • Arduino Uno / Nano
  • 16x2 LCD (HD44780)
  • Carrera Control Unit (PC UNIT port)
LCD wiring:
RS → 11
EN → 12
D4 → 2
D5 → 3
D6 → 4
D7 → 5
Serial connection (PC UNIT):
TX → RX (Arduino Pin 0)
RX → TX (Arduino Pin 1)
5V → 5V
GND → GND
Important notes:
  • First lap is ignored (startup condition)
  • Uses String and readStringUntil() (blocking)
  • Works only for 2 cars currently
Code:
#include <LiquidCrystal.h>
// LCD pin configuration
const int rs = 11;  // Register Select pin
const int en = 12;  // Enable pin
const int d4 = 2;   // Data pin 4
const int d5 = 3;   // Data pin 5
const int d6 = 4;   // Data pin 6
const int d7 = 5;   // Data pin 7
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// Timing variables for both cars
unsigned long lapStartTime1 = 0;
unsigned long lapStartTime2 = 0;
unsigned long lapTime1 = 0;
unsigned long lapTime2 = 0;
// Stores the best lap time recorded so far
unsigned long bestTime = 999999999;
// Flags to ignore the very first lap (invalid timing)
bool first1 = true;
bool first2 = true;
// Custom LCD character (crown)
// Indicates the current fastest car
byte crown[8] = {
  0b00000,
  0b00000,
  0b00000,
  0b10101,
  0b11111,
  0b11111,
  0b00000,
  0b00000
  Serial.begin(19200);   // Communication with Carrera Control Unit
  lcd.begin(16, 2);      // Initialize 16x2 LCD
  lcd.print("Starting...");
  lcd.createChar(0, crown);  // Store custom crown character
  lcd.clear();
  // Static LCD layout
  lcd.setCursor(0, 0);
  lcd.print("Car1:");
  lcd.setCursor(0, 1);
  lcd.print("Car2:");
  // Placeholder for lap times
  lcd.setCursor(6, 0);
  lcd.print("--.--");
  lcd.setCursor(6, 1);
  lcd.print("--.--");
  // Best lap display
  lcd.setCursor(12, 0);
  lcd.print("BEST");
  lcd.setCursor(12, 1);
  lcd.print("-.--");
  // Request data from the Control Unit
  Serial.print("\"?");
  // Check if data is available
  if (Serial.available()) {
    // Read incoming data until '$' delimiter
    String incomingData = Serial.readStringUntil('$');
    // Ensure the received data is long enough
    if (incomingData.length() > 10) {
      // Check if sensor group 1 was triggered
      if (incomingData.charAt(10) == '1') {
        // Car 1 detected
        if (incomingData.charAt(1) == '1') {
          lapTime1 = millis() - lapStartTime1;
          lapStartTime1 = millis();
          // Update display for Car 1
          lcd.print("     ");  // Clear previous value
          lcd.print(lapTime1 / 1000.0);
          besttime();
          first1 = false;
        // Car 2 detected
        if (incomingData.charAt(1) == '2') {
          lapTime2 = millis() - lapStartTime2;
          lapStartTime2 = millis();
          lcd.print("     ");
          lcd.print(lapTime2 / 1000.0);
          besttime();
          first2 = false;
// Updates the best lap time
// and moves the crown indicator
void besttime() {
  // New best lap from Car 1
  if (lapTime1 < bestTime && !first1) {
    bestTime = lapTime1;
    // Move crown to Car 1
    lcd.setCursor(5, 1);
    lcd.print(" ");           // Remove previous crown
    lcd.setCursor(5, 0);
    lcd.write(byte(0));       // Draw crown
    // Update best time display
    lcd.print("    ");
    lcd.print(bestTime / 1000.0);
  // New best lap from Car 2
  if (lapTime2 < bestTime && !first2) {
    bestTime = lapTime2;
    lcd.print(" ");
    lcd.write(byte(0));
    lcd.print("    ");
GitHub:
Instructables
I would appreciate feedback, especially on improving the serial parsing and avoiding blocking calls.
