CH340 drivers on Windows
Getting around the upload problem with CH340 usb-serial i found installing the 2019 driver works. Newest driver does give the "A fatal esptool.py error occurred: Cannot configure port, something went wrong" error.
Strangely with newer driver the serial console works fine, just the upload does not.
Hi @hadmut. Is the USB chip on your board labeled? Something like this:
SparkFun - CC BY-SA 4.0 (cropped)
Or is it instead blank? Like this:
NodeMCU Lua Lol1n V3.jpg by Popolon - CC BY-SA 4.0 (cropped)
And it works until windows10 restarts. Then it "updates" the working driver with the not working one. To prevent this, make the old 2019 driver in sytem32/drivers read-only, not deletable. Name is CH341, 3 files.
Its blank, but i think it doesent matter. Win10 auto installs a non-working driver.
I would recommend instead using the intended "roll back" mechanism for pinning a driver version. When you do that, Windows understands that you are intentionally using the older driver version, and won't revert the change by updating it once again. In case it will be useful to you, I'll provide instructions:
  1. Click the following link to download the previous version of the driver from an archive of the chip manufacturer's website:
    https://web.archive.org/web/20220519153932/https://www.wch-ic.com/downloads/file/65.html
  2. Wait for the download to finish.
  3. Run the downloaded CH341SER.EXE file.
  4. A "User Account Control" dialog may now appear asking "Do you want to allow this app to make changes to your device?". Click the "Yes" button.
  5. A "DriverSetup(X64)" dialog will open. Click the "INSTALL" button in the dialog.
  6. Wait for the driver installation to finish, as indicated by the appearance of a "Driver install success!" dialog.
  7. Click the "OK" button in the "Driver install success!" dialog.
    The dialog will close.
  8. Click the X icon at the top right of the "DriverSetup(X64)" dialog
  9. Close Arduino IDE if it is running.
  10. Connect the Arduino board to your computer with a USB cable.
  11. Open the Windows Device Manager.
  12. Select View > Devices by type from the Device Manager menus.
  13. Open the "View" menu.
  14. If there is a to the left of the "Show hidden devices" menu item, click on "Show hidden devices" to disable it.
  15. Open the "Ports (COM & LPT)" section of the Device Manager tree.
  16. You should see a port identified as "USB-SERIAL CH340 (COMn)" under the "Ports (COM & LPT)" section (where "COMn" is some serial port e.g., COM4). Double click on that item.
    The "USB-SERIAL CH340 (COMn) Properties" dialog will open.
  17. Select the "Driver" tab of the "USB-SERIAL CH340 (COMn) Properties" dialog.
  18. You will see a "Roll Back Driver" button in the dialog. If it is not clickable, perform the following instructions:
    1. Click the "Update driver" button.
      An "Update Drivers Device - USB-SERIAL CH340 (COMn)" dialog will open.
    2. Click on "Search automatically for drivers" in the "Update Drivers Device - USB-SERIAL CH340 (COMn)" dialog.
    3. You should now see the driver installation wizard update the driver. Wait for the update to finish, as indicated by the message "Windows has successfully updated your drivers" in the dialog.
      :red_exclamation_mark: It is possible you will instead see the message "The best drivers are already installed". If so, please stop following the instructions here and reply on this forum topic to let us know. I'll provide alternative instructions you can follow.
    4. Click the "Close" button in the "Update Drivers Device - USB-SERIAL CH340 (COMn)" dialog.
  19. Click the "Roll Back Driver" button in the "USB-SERIAL CH340 (COMn) Properties" dialog.
    The "Driver Package rollback" dialog will open.
  20. Click the radio button next to "My apps don't work with this driver" in the "Driver Package rollback" dialog .
  21. Click the "Yes" button.
    The "Driver Package rollback" dialog will close.
  22. Click the "Close" button in the "USB-SERIAL CH340 (COMn) Properties" dialog.
It does indeed matter. The legitimate WCH CH340 chips work perfectly well with the modern driver version. It is only the sketchy blank chips found on the supiciously cheap Chinese boards sold by unscrupulous sellers on the less vigilant marketplaces (e.g., AliExpress) that misbehave when used with any driver version newer than 3.7.2022.01.
