Change a variable using serial
My code
String serial;
int dotLocation[] = {};
int a = 0;
int r = 0;
int g = 0;
int b = 0;
  serial = Serial.readString();
  for(int i = 0;i<serial.length();i++) {
    if (serial.charAt(0) == 'i') {
      while(serial.charAt(i) == isAlphaNumeric) {
        Serial.println(i);
        a = serial.charAt(i);
  Serial.println(a);
So my problem is that i want every number after i to be added to the variable a;
But for some reason it doesn't add anything so the value of that variable stays at 0;
Can you guys take a look at my code and tell what's wrong. I am in a kind of a hurry because i would want my code to be finished in time for a demoparty.
Your use of isAlphaNumeric is wrong.
See isAlphaNumeric() - Arduino Reference.
Thank you for a quick response. What should i use instead to detect if the character is a numeral?
What I was trying to indicate is that isAlphaNumeric is a function and it takes a parameter. See the example in the link I gave you.
By the way, if you want to check for numbers only, isNumeric is the correct function.
