I have decimal code below, when I type the X number on keypad it moves the stepper as decimal inch to the X number , I need to make this 1/64 of an inch fractional, it can still move same as decimal but i need to type fraction for example 12 23/64" or maybe 12-23/64. I can assign keypad key A=/ and B=-
also second question is it possible to go below 0 to -12 23/64
thank you
Ozan.
#include <AccelStepper.h> // AccelStepper Library
#include <Keypad.h> // Keypad Library
#include <Wire.h>
#define I2C_ADDR 0x3F // Add your address here.
#define Rs_pin 0
#define Rw_pin 1
#define En_pin 2
#define BACKLIGHT_PIN 3
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
// Global variables
byte index = 0;
char numbers[16]; // Plenty to store a representation of a float
// Keypad Setup
const byte ROWS = 4; // Four Rows
const byte COLS = 4; // Four Columns
char keys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', '.'}
byte rowPins[ROWS] = {22, 24, 26, 28}; // Arduino pins connected to the row pins of the keypad
byte colPins[COLS] = {31, 33, 35, 37}; // Arduino pins connected to the column pins of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS ); // Keypad Library definition
// AccelStepper Setup
AccelStepper stepper(1, A2, A3); // 1 = Easy Driver interface
// Arduino A2 connected to STEP pin of Easy Driver
// Arduino A3 connected to DIR pin of Easy Driver
static char outstr[15];
void setup(void) {
float len = 000.000;
// AccelStepper speed and acceleration setup
stepper.setMaxSpeed(22000);
stepper.setAcceleration(10000);
lcd.begin (20, 4); // our LCD is a 20x4, change for your LCD if needed
// LCD Backlight ON
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
lcd.setBacklight(HIGH);
char key = keypad.getKey();
if (key != NO_KEY)
lcd.print(key);
if (key == 'C')
index = 0;
numbers[index] = '\0';
else if (key == '.')
numbers[index++] = '.';
else if (key >= '0' && key <= '9')
numbers[index++] = key;
else if (key == '#')
float len = atof(numbers);
dtostrf(len, 7, 3, outstr);
lcd.clear();
lcd.setCursor (13, 3);
lcd.print(outstr);
stepper.runToNewPosition(len * 1354.666666665203627); // steps for 1 inch
index = 0;
}/code]
