Change Text Size on lvgl
Hey. I want to change the text size on my Display in the boxes of the following code. But I dont know how.
Can someone help?
#include "Arduino_H7_Video.h"
#include "Arduino_GigaDisplayTouch.h"
#include "lvgl.h"
Arduino_H7_Video          Display(800, 480, GigaDisplayShield); /* Arduino_H7_Video Display(1024, 768, USBCVideo); */
Arduino_GigaDisplayTouch  TouchDetector;
static void scroll_event_cb(lv_event_t * e)
    lv_obj_t * cont = lv_event_get_target(e);
    lv_area_t cont_a;
    lv_obj_get_coords(cont, &cont_a);
    lv_coord_t cont_y_center = cont_a.y1 + lv_area_get_height(&cont_a) / 2;
    lv_coord_t r = lv_obj_get_height(cont) * 7 / 10;
    uint32_t i;
    uint32_t child_cnt = lv_obj_get_child_cnt(cont);
    for(i = 0; i < child_cnt; i++) {
        lv_obj_t * child = lv_obj_get_child(cont, i);
        lv_area_t child_a;
        lv_obj_get_coords(child, &child_a);
        lv_coord_t child_y_center = child_a.y1 + lv_area_get_height(&child_a) / 2;
        lv_coord_t diff_y = child_y_center - cont_y_center;
        diff_y = LV_ABS(diff_y);
        /*Get the x of diff_y on a circle.*/
        lv_coord_t x;
        /*If diff_y is out of the circle use the last point of the circle (the radius)*/
        if(diff_y >= r) {
            x = r;
        else {
            /*Use Pythagoras theorem to get x from radius and y*/
            uint32_t x_sqr = r * r - diff_y * diff_y;
            lv_sqrt_res_t res;
            lv_sqrt(x_sqr, &res, 0x8000);   /*Use lvgl's built in sqrt root function*/
            x = r - res.i;
        /*Translate the item by the calculated X coordinate*/
        lv_obj_set_style_translate_x(child, x, 0);
        /*Use some opacity with larger translations*/
        lv_opa_t opa = lv_map(x, 0, r, LV_OPA_TRANSP, LV_OPA_COVER);
        lv_obj_set_style_opa(child, LV_OPA_COVER - opa, 0);
 * Translate the object as they scroll
void lv_example_scroll_6(void)
    lv_obj_t * cont = lv_obj_create(lv_scr_act());
    lv_obj_set_size(cont, 400, 400);
    lv_obj_center(cont);
    lv_obj_set_flex_flow(cont, LV_FLEX_FLOW_COLUMN);
    lv_obj_add_event_cb(cont, scroll_event_cb, LV_EVENT_SCROLL, NULL);
    lv_obj_set_style_radius(cont, LV_RADIUS_CIRCLE, 0);
    lv_obj_set_style_clip_corner(cont, true, 0);
    lv_obj_set_scroll_dir(cont, LV_DIR_VER);
    lv_obj_set_scroll_snap_y(cont, LV_SCROLL_SNAP_CENTER);
    lv_obj_set_scrollbar_mode(cont, LV_SCROLLBAR_MODE_OFF);
    uint32_t i;
    for(i = 0; i < 6; i++) {
        lv_obj_t * btn = lv_btn_create(cont);
        lv_obj_set_width(btn, lv_pct(600));
        lv_obj_set_height(btn, lv_pct(50));
        lv_obj_t * label = lv_label_create(btn);
        //lv_label_set_text_fmt(label, "Butt %"LV_PRIu32, i);
        if (i == 0) lv_label_set_text_fmt(label, "Mixing Process");
        if (i == 1) lv_label_set_text_fmt(label, "Single Process");
        if (i == 2) lv_label_set_text_fmt(label, "Free Spot 1");
        if (i == 3) lv_label_set_text_fmt(label, "Free Spot 2");
        if (i == 4) lv_label_set_text_fmt(label, "Cleaning Process");
        if (i == 5) lv_label_set_text_fmt(label, "Settings");
    /*Update the buttons position manually for first*/
    lv_event_send(cont, LV_EVENT_SCROLL, NULL);
    /*Be sure the fist button is in the middle*/
    lv_obj_scroll_to_view(lv_obj_get_child(cont, 0), LV_ANIM_OFF);
  Display.begin();
  TouchDetector.begin();
  lv_example_scroll_6();
  lv_timer_handler();
Thank you!
Hi See my reply to another Giga Display user with similar issue, one that I also scratched my head over. Hope it helps.
Giga R1 Display Shield with LVGL font issues
