Change value of int every revolution of a stepper motor
#include <AccelStepper.h>
#include <Wire.h>
#include <Keypad.h>
#include <SPI.h>
AccelStepper stepper1(AccelStepper::FULL2WIRE, 10, 11);//Cardiac
AccelStepper stepper2(AccelStepper::FULL2WIRE, 12, 13);//Pulmonary
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = {6, 5, 4, 3}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {9, 8, 7}; //connect to the column pinouts of the keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int spd = 1000;    // The current speed in steps/second
int sign = 1;      // Either 1, or 0. Can use to change to reverse if sign= -1
String RPM=("RPM");
String Steps=("Steps per Second");
String disp=("Running at:"); //A display string so user knows input will be performed
String disp2=("Steps per Second:"); //Secondary Display String
int input=0;
int z=0;//Changes to 1 and causes Cardiac Signal Generator to send signal
int posit=stepper1.currentPosition();//Determines position of stepper1. If position reaches zero again it triggers z=1;
  Serial.begin(115200); //set baud rate to 115200 for usart
   digitalWrite(SS, HIGH); // disable Slave Select
   SPI.begin ();
   SPI.setClockDivider(SPI_CLOCK_DIV2);//divide the clock by 8
  lcd.begin(20,4);
  lcd.setCursor(0,0);
  stepper1.setMaxSpeed(128000); //Setting max speed of 240 RPM if Steps are 400 On Off On
  stepper1.setAcceleration(500); //Max acceleration
  stepper1.setSpeed(1600);    //Initial Starting Speed, not important, 2133=80-  3200=120 RPM only for stepper1();
                              //Because of Step Rate of stepper1(); driver
  stepper2.setMaxSpeed(100000); //Setting max speed of 240 RPM if Steps are 400 On Off On
  stepper2.setAcceleration(500); //Max acceleration
  stepper2.setSpeed(3200);    //Initial Starting Speed, not important, 2133=20 RPM only for stepper2();
                              //because of Step Rate of stepper1(); driver
  lcd.print("Enter RPM for");
  lcd.setCursor(0,1);
  lcd.print("Stepper 1 (60 RPM)");
  lcd.setCursor(0,2);
  lcd.print("Add 1000 to RPM to");
  lcd.setCursor(0,3);
  lcd.print("change Stepper 2 20");
  String input_String; //String for receving Serial.read(); and converting to int value_RPM
  String num; //A display string so user knows input will be performed at num RPM
  int key=kpd.getKey();
  if(key != NO_KEY){ //Making sure key is available before taking any action
    if(key == '#'){
    lcd.setCursor(0,2);
    lcd.print("Received:"); //Letting user know input was received
    lcd.setCursor(0,3);
    lcd.print(input);  //Printing what int we got
    while(input==8888){
      stepper1.setAcceleration(11000);
      stepper1.runToNewPosition(1600);
      stepper1.setCurrentPosition(0);
      stepper2.run();
    if(input==9999){
      stepper1.setSpeed(0);
      stepper2.setSpeed(0);
      lcd.clear();
      lcd.print("All motion stopped");
      lcd.setCursor(0,1);
      lcd.print("Press reset button:");
      lcd.setCursor(0,2);
      lcd.print("Resume Motion or");
      lcd.setCursor(0,3);
      lcd.print("Turn off power");
    else if (input >= 1000 && input <= 2000){ //This if only for stepper 2, makes sure that the input is over 1000 so we know
                        //User wants to modify stepper 2. Add 1000 to whatever RPM value you desire to control stepper 2
      lcd.clear();
      lcd.print("Modifying speed of Stepper 2");
      input = input-1000; //Once confirmed that stepper 2 is being controlled, reduce to normal values and function normally
      if (input == 1) {  // Rotates forward, useless for now but if you want to add reverse functionality it is useful
      disp=("Rotating Forward");
      sign = 1;
    else if (input == 0){  // stop. Once stopped, it will not restart
      disp=("Rotation Stopping \n");
      spd = 0;
      num= "0";
      lcd.clear();
      lcd.print("You have stopped the motor. To resume motion, reupload the program");
    else{
      spd=input*213.3333; //Ratio for 1600 Steps
                        //stepper1(); as the steps/rev are different
      num=(spd);        //Convert spd back to string to display and manipulate easier
    stepper2.setAcceleration(6400);
    stepper2.setSpeed(sign * spd); //Keep this for future reverse functionality
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(disp + input + " " + RPM); //Final confirmation of action Arduino is taking
    lcd.setCursor(0,1);
    lcd.print(disp2); //Displayed in steps per second
    lcd.setCursor(0,2);
    lcd.print(num + " For Stepper 2");
    lcd.setCursor(0,3);
    lcd.print("Ready for RPM change");
   else if(input<1000){ //This else for only stepper 1
    lcd.clear();
    lcd.print("Modifying speed of Stepper 1");
        spd = 0;
        num= "0";
        lcd.clear();
    else{
      spd=input*26.6667; //Ratio for 400 steps
                        //The second motor as the steps/rev are different
      stepper1.setAcceleration(6400);
      stepper1.setSpeed(sign * spd); //Keep this for future reverse functionality
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.setCursor(0,2);
      lcd.print(num + " For Stepper 1");
      lcd.setCursor(0,3);
    input=0;
  else{
    input = input*10;
    input = input + key - '0';
    lcd.clear();
    lcd.print(input);
  if(posit==0){
    digitalWrite(SS, LOW); // enable Slave Select
   z=1;
      SPI.transfer (z);
  z=0;
  stepper1.runSpeed(); //Running arduino at desired speed
  stepper2.runSpeed();
Essentially, I'm running two arduino Mega2560 on an SPI connection.
This is the master code. My slave works as intended. I am attempting to change the value of int z; from z=0; to z=1; whenever the stepper1(); completes 1 revolution. I am attempting to do this by using int posit=stepper1.currentPosition(); and setting that value as zero at the beginning of the program. And I want to constantly assess it until posit=0; again when I know that the stepper1(); has completed one revolution because its step value is 0. Are there better ways of assessing it? Or did I just place my currentPosition(); calls in the wrong places?
Apologies in advance for the messy code. This is the last thing I have to do for it and afterwards I'm gonna clean it up properly.
What stepper motor driver are you using?
If you are using a driver that takes step and direction inputs then you should use DRIVER rather than FULL2WIRE
As you are using runSpeed() you are not using acceleration so maybe there is no advantage using the AccelStepper library. If you just use your own code to cause the steps you can easily keep track of the position. See the second example in this Simple Stepper Code
...R
Stepper Motor Basics
For full stepping something like this could work:
int revcount()
  return stepper.currentPosition() / 200 ;
(assuming full steps, multiply the 200 for microstepping, beware negative values need special case)
Delta_G-
Yeah haha I realized that. That's an unused feature I was working in but just never took out of the code.
Robin2-
I attempted to use the basic stepper library at first but for some reason I switched to accelstepper for my needs. I can't remember the reason however as I started this project a long time ago.
MarkT-
Your code didn't produce a change in the signal. It still acts as if the stepper's position is always at zero and thus does z=1; every cycle of void loop(). Any other suggestions?
Somark:
One possible reason is that you wanted to use a stepper driver that takes step and direction signals.
And maybe you don't really need the AccelStepper library.
...R
