Changing arrays
OK, so I have 3 arrays of 10 values. I wish to be able to change through these arrays with the press of a button, but I'm having trouble changing the arrays.
I have in my code, the variable "currarray", which is the current array. I also have 3 other arrays, array1[10], array2[10] and array3[10]
Somehow, I need to put any of those 3 arrays, into currarray?
For example, I tried:
byte currarray[] = array1[];
However, I get error messages.
I also tried byte currarray = array1;
Still didn't work.
A snippet of my code:
byte array1[10] = {36, 41, 43, 44, 46, 48, 49, 51, 53, 55};
byte array2[10] = {35, 47, 54, 55, 57, 59, 60, 61, 62, 64};
byte array3[10] = {48, 60, 62, 63, 65, 67, 69, 70, 72, 74};
         if (digitalRead(BUTTON_1) == LOW){
           if (currarray[] == array1[]){
             currarray[] = array2[];
             digitalWrite(18, HIGH);
             digitalWrite(17, LOW);
             digitalWrite(19, LOW);
           if (currarray[] == array2[]){
             currarray[] = array3[];
             digitalWrite(19, HIGH);
             digitalWrite(18, LOW);
           if (currarray[] == array3[]){
             digitalWrite(17, HIGH);
How would I go about doing this?
Regards
Make a multidimensional array of it
#define BUTTON_1  4
byte array[3][10] = {
  {36, 41, 43, 44, 46, 48, 49, 51, 53, 55},
  {35, 47, 54, 55, 57, 59, 60, 61, 62, 64},
int arrayselector= 0;  // may also be called differently but meaningfull var names helps to understand code.
    arrayselector= (arrayselector+ 1) %3;  // changes from 0->1->2->0
  Serial.println(array[arrayselector][4]);
The button just changes the arrayselector from 0->1->2->0
Thanks, that is exactly what I was wanting :wink:
Regards,
Dan
one way would have been to use a for loop.
e.g.
for (int i=0; i<10; i++) {
array1[i] = currarray[i];
if you wanted to be able to switch between arrays u could make 3 different for loops and use switch case.
But i think you could use pointers to not to sure on how maybe somebody here knows
Use a pointer.
byte* currarray;
byte array1[10] = {1,2,3,...}
byte array2[10] = {11,12,13,...}
