I know can use this library. But I dont want to use it. I want to do it by myself. I tried this
#include <EEPROM.h>
const int EEPROM_MIN_ADDR = 0;
const int EEPROM_MAX_ADDR = 511;
boolean eeprom_is_addr_ok(int addr) {
return ((addr >= EEPROM_MIN_ADDR) && (addr <= EEPROM_MAX_ADDR));
boolean eeprom_write_bytes(int startAddr, const byte* array, int numBytes) {
// counter
int i;
if (!eeprom_is_addr_ok(startAddr) || !eeprom_is_addr_ok(startAddr + numBytes)) {
return false;
for (i = 0; i < numBytes; i++) {
EEPROM.write(startAddr + i, array[i]);
return true;
boolean eeprom_write_string(int addr, const char* string) {
int numBytes;
numBytes = strlen(string) + 1;
return eeprom_write_bytes(addr, (const byte*)string, numBytes);
boolean eeprom_read_string(int addr, char* buffer, int bufSize) {
byte ch; // byte read from eeprom
int bytesRead;
if (!eeprom_is_addr_ok(addr)) {
return false;
if (bufSize == 0) {
return false;
if (bufSize == 1) {
buffer[0] = 0;
return true;
bytesRead = 0; // initialize byte counter
ch = EEPROM.read(addr + bytesRead);
buffer[bytesRead] = ch;
bytesRead++;
while ( (ch != 0x00) && (bytesRead < bufSize) && ((addr + bytesRead) <= EEPROM_MAX_ADDR) ) {
bytesRead++;
if ((ch != 0x00) && (bytesRead >= 1)) {
buffer[bytesRead - 1] = 0;
return true;
String read_StringEE(int Addr, int length)
char cbuff[length+1];
eeprom_read_string(Addr, cbuff, length+1);
String stemp(cbuff);
return stemp;
bool write_StringEE(int Addr, String input)
char cbuff[input.length()+1];//Finds length of string to make a buffer
input.toCharArray(cbuff,input.length()+1);//Converts String into character array
return eeprom_write_string(Addr,cbuff);//Saves String
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
IPAddress local_IP(192,168,4,2);
IPAddress gateway(192,168,4,1);
IPAddress subnet(255,255,255,0);
ESP8266WebServer server(80);
void clientCfg();
void APcfg();
const char* ssid = "OFFLINE";
const char* pswd = "";
//const int channel = 9;
int length = 16;
int ssidAdd = 0;
int passAdd = 18;
String setting;
String user;
String pass;
char* ssid1;
char* pass1;
const char* ssid2;
const char* pass2;
const char* pass3;
const char* ssid3;
boolean state;
EEPROM.begin(512);
/*for (int i=0; i<512; i++)
EEPROM.write(i, 0);
EEPROM.commit();
if(EEPROM.read(0)==0 && EEPROM.read(18)==0)
state = false;
state = true;
if(state==false)
APcfg();
if(state==true)
clientCfg();
server.handleClient();
void APcfg()
delay(100);
//WiFi.mode(WIFI_AP);
delay(10);
Serial.print("Configuring SoftAP Configuration...");
Serial.println(WiFi.softAPConfig(local_IP, gateway, subnet)? "Ready" : "Failed!");
delay(10);
Serial.print("Setting SoftAP...");
Serial.println(WiFi.softAP(ssid, pswd)? "Ready": "Failed!");
delay(10);
Serial.print("connect to the IP Address given below...");
Serial.println(WiFi.softAPIP());
delay(10);
setting = "<form action=\"http://192.168.4.2/iron_fist\" method = \"post\">"
"New Password:
"<input type=\"text\" placeholder=\"WiFi\" name =\"user\">"
"<input type=\"password\" placeholder=\"Enter Password\" name =\"psw\">"
"<input type=\"submit\" value=\"Submit\">"
"</form> ";
server.on("/", [] () {server.send(200, "text/html", setting);});
server.on("/iron_fist", ironfist);
server.begin();
void clientCfg()
//delay(300);
eeprom_read_string(ssidAdd,ssid1,length);
ssid2 = ssid1;
//delay(300);
eeprom_read_string(passAdd,pass1,length);
pass2 = pass1;
delay(300);
//WiFi.mode(WIFI_AP_STA);
delay(300);
Serial.print("connecting to.....");
Serial.println(ssid2);
WiFi.begin(ssid2,pass2);
while(WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.print(".....Connect to the WiFi and open the IP address given below.....");
Serial.println("IP address:-");
//delay(1000);
//delay(1000);
server.on("/", client);
void ironfist()
if(server.args()!=NULL)
for (uint8_t i=0; i<server.args(); i++)
if(server.argName(i)=="user")
Serial.println("SSID Received: -");
user = server.arg(i);
Serial.print(user);
ssid3 = user.c_str();
if (user=="")
eeprom_write_string(ssidAdd,ssid3);
EEPROM.commit();
Serial.println("SSID stored");
if(server.argName(i)=="psw")
Serial.println("Password Received: -");
pass = server.arg(i);
Serial.print(pass);
pass3 = pass.c_str();
eeprom_write_string(passAdd,pass3);
EEPROM.end();
Serial.println("Password Stored");
ESP.restart();
void client()
server.send(200, "text/plain", "Hello world!");
it worked completely fine as SoftAP but shows Exception (29) when it has to connect to the WiFi.
Below is the error
Exception (29):
epc1=0x40202178 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff03e0 end: 3fff0610 offset: 01a0
>>>stack>>>
3fff0580: feefeffe feefeffe 3fff1744 40201cf9
3fff0590: 00000000 00000001 00000010 feefeffe
3fff05a0: 00000000 400042db feefeffe 3ffef5dc
3fff05b0: 3ffeeaf8 3ffef430 3ffe8350 40202397
3fff05c0: 00000001 feefeffe feefeffe 402062d4
3fff05d0: 40205629 3ffef430 00000200 3ffef5dc
3fff05e0: 3fffdad0 3ffef430 3ffeeae0 402024b6
3fff05f0: feefeffe 00000000 3ffef5d4 402063e0
3fff0600: feefeffe feefeffe 3ffef5f0 40100718
<<<stack<<<
I tried to find what is Exception (29) using ESP Exception decoder it said
Exception 29: StoreProhibited: A store referenced a page mapped with an attribute that does not permit stores
But I am unable to solve this.
