Changing Global Variables From WIthin an ISR
Hi, I'm trying to change the value of a global variable from within the timer's ISR, and for the life of me I can't get it to stick.
The variable is declared:
volatile int var;
Then in setup() I initialize it to 0:
var = 0;
and in the ISR I increment it:
var++;
It will increment it in the ISR, but it really seems like it's incrementing a local copy of the variable, because as soon as it returns from the timer's handler, the value returns to zero, so incrementing it this way simply makes it toggle between 0 and 1. If I increment it in the loop() function, the changes stay, but just not in the handler. Does anyone know why this is happening?
Thanks!
It would help a lot to see the full source.
Be sure to post code using the [#] button :slight_smile:
Well that's how I declare a variable in a optical encoder program I use that has a ISR to increment or decrement the global variable, and it works fine. Perhaps if you posted your code.
Lefty
Awesome, thanks. I didn't want to innundate y'all if this was a standard thing in the language. I've cut out some stuff trying to isolate the problem, so that's why there are a might be a few random variables floating around that don't really do anything... Also this is obviously not the final goal, but just distilled down to just the problem.
volatile unsigned int timeInDutyCycle;
  // Enable Timer/Counter 1 Overflow interrupt pg 139
  TIMSK1 |= (1<<TOIE1) | (1<< OCIE1A);
  // Setting the prescalar to 8 pg 137
  TCCR1B |= (1<<CS11);
  TCCR1B &= ~((1<<CS10) | (1 << CS12));
  // Normal operation (no funny buisness)
  TCCR1A = 0x00;
  timeInDutyCycle = 0;
  Serial.println(timeInDutyCycle);
ISR(TIMER1_OVF_vect) {
  timeInDutyCycle++;
So I got it working, but I have no idea why it worked.
When I deactivated the Compare A interrupt, it just started working like a charm. I don't suppose anyone knows why this might happen? I didn't have a ISR for the compare A interrupt, so I wouldn't have thought it would reset it...
All interrupt vectors are by default assigned to a BADISR service routine and the default implementationn for this routine is to restart the application. So whenever the CompareA interrupt was triggered, your sketch would restart and never get beyond 0/1.
Awesome, thank you VERY much. That's good to know.
