Changing TCP listening port - ESP8266 OK! ESP32 NOT OK!
Hello,
When using the Arduino IDE and the ESP8266 we declare a global WiFiServer before the setup() code like this:
WiFiServer myServer(0); // to be changed later at run-time
and later in the setup code or in the loop code we could change the listening port like this:
myServer.begin(myPort);
This is useful when the port number for TCP communication is not previously defined or when it is defined by the user during a setup phase.
Unfortunately this does not work with the ESP32. If we do the same we got this error:
no matching function for call to 'WiFiServer::begin(unsigned int&)'
I wonder if there is a way to bypass this problem without "à priori" fixing the port number.
Regards, Luis
Sure. Don't create the WiFiServer instance (myServer is a stupid name for the instance) until you have all the data that you need.
Typically, this means that you make the WiFiServer variable a pointer and use new to create the instance, and then use pointer notation (->) instead of object notation (.) to access the methods.
Hello again,
I am sorry for my post. Actually it is possible to change the TCP port at run time as we do with the ESP8266. I was not using the 1.0.0 ESP32 core for Arduino. Once installed the begin method accepts a parameter and there is no error.
Regards Luis
