Hello
I have a project where I need to use a different pin for the SD card SS (CS?) connection (pin usage clash).
I am using the SD.h library.
I have found the pin allocations in 'Sd2PinMap.h', but didn't really want to change them in there if I could help it (it will break other projects).
Is it possible to re-declare the SS pin pin allocation from the one declared in Sd2PinMap.h, within your programming at the start?
If it is, I cannot find such a command line.
Thanks!
