ThatOne
1
I'm currently working on a project for which I need to have this for loop:
for(int x = 0; x < 9; x++){
if(Pin1 == 1 && Pin2 == 0){
data = 1;
What i need to do is something like:
for example if x is 5:
data5 = 1;
So what i need is to change the name of the variable depending on x in the for-loop.
Is this even possible?
And if it is, how can i do this?
system
2
No. At run time, variables have addresses, not names.
Using an array is almost certainly the answer to whatever you are trying to do.
KeithRB
3
A large if chain and a pointer
ThatOne:
if (Pin1 == 1 && Pin2 == 0){
data5 = 1;
If x = 5, why not something like:
int data[10];
data[x] = 1;
jurs
5
ThatOne:
data5 = 1;
You might want to use an array like
int data[10];
Then you can access each element of the array by either a constant index like
[data[5]
Or in a for-loop with loop index i you could address an element by coding
data[i]
