Char Data Type issues
Dear all
I am rather new in the C++ Arduino world but managed to make my project mostly work. However I have some issues with the char datatype as I could not figure out how to convert the data to make my "if query" work.
Setup: My Android App sends characters via Bluetooth to my ESP32 (and alternatively Arduino UNO) and I receive this commands as a set of characters in my code named receivedChars
I can perfectly display the variable receivedChars using Serial function on both my Terminal and the 7735 TFT Display. However I do not know how I can perform a query with it as there seems a datatype mismatch or a kind of:
if (receivedChars == ("1152a1a"))
It does compile but I get the warning:
comparison with string literal results in unspecified behaviour [-Waddress]
** if (receivedChars == ("1152a1a"))**
As I understand I cannot compare receivedChars with my Characters "1152a1a". But how can I achieve this?
Any help or suggestion would be much appreciated.
Kind regards
Pls find the code below:
#include <Arduino.h>
#include <BluetoothSerial.h>
#include <Adafruit_GFX.h>    // include Adafruit graphics library
#include <Adafruit_ST7735.h> // include Adafruit ST7735 TFT library
#include <Adafruit_I2CDevice.h>
// ST7735 TFT module connections
#define TFT_RST 26 // TFT RST pin is connected to
#define TFT_CS 5   // TFT CS  pin is connected to
#define TFT_DC 17  // TFT DC  pin is connected to
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
BluetoothSerial Serial_BT;
const byte numChars = 8;      // Input function
char receivedChars[numChars]; // Input function
boolean newData = false; // Input function
char *destination[] = {"St. Moritz", "Celerina", "Samedan", "Spinas", "Preda", "Berg\201n", "Filisur", "Thusis", "Reichenau-T.", "Chur"};
void callback(esp_spp_cb_event_t event, esp_spp_cb_param_t *param)
  if (event == ESP_SPP_SRV_OPEN_EVT)
    Serial.println("Client Connected");
  if (event == ESP_SPP_CLOSE_EVT)
    Serial.println("Client disconnected");
void recvWithStartEndMarkers()
  static boolean recvInProgress = false;
  static byte ndx = 0;
  char startMarker = '<';
  char endMarker = '>';
  char rc;
  while (Serial_BT.available() > 0 && newData == false)
    rc = Serial_BT.read();
    if (recvInProgress == true)
      if (rc != endMarker)
        receivedChars[ndx] = rc;
        ndx++;
        if (ndx >= numChars)
          ndx = numChars - 1;
        receivedChars[ndx] = '\0'; // terminate the string
        ndx = 0;
        newData = true;
    else if (rc == startMarker)
      recvInProgress = true;
void showNewData()
  if (newData == true)
    Serial.print("Characters received:");
    Serial.println(receivedChars);
    newData = false;
  Serial_BT.register_callback(callback);
  if (!Serial_BT.begin("Bluetooth ESP32"))
    Serial.println("An error occurred initializing Bluetooth");
    Serial.println("Bluetooth initialized");
  tft.initR(INITR_BLACKTAB);    // initialize a ST7735S chip, black tab
  tft.fillScreen(ST7735_WHITE); // fill screen with black color
  tft.setRotation(-1);
  //tft.drawFastHLine(0, 44,  tft.width(), ST7735_ORANGE);    // draw horizontal blue line at position (0, 44)
  tft.setTextColor(ST7735_ORANGE, ST7735_WHITE); // set text color to white and black background
  tft.setTextWrap(false);                        // Don't wrap text to next line
  tft.setTextSize(1);                            // text size = 1
  tft.setCursor(4, 27); // move cursor to position (4, 27) pixel
  tft.printf(destination[5]);
  recvWithStartEndMarkers(); // Input function
  showNewData();             // Input function
    Serial.println("Display Case 1");
    tft.setCursor(20, 25); // move cursor to position (, ) pixel
    tft.setTextSize(1);
    tft.printf("Display Case 1");
    delay(3000);
  if (receivedChars == ("1152a2"))
    Serial.println("Display Case 2");
    tft.setTextSize(1);
    tft.printf("Display Case 2");
    delay(3000);
After receiving/storing 8 charcaters into the receivedChars[numChars] array, insert null-byte (0x00 = '\0') as the last element into the said array and then perform the following codes if applicable:
bool n = strcmp(receivedChars, "1152a1a");  //strcmp = string compare
if( n == 0)
     //received string has matched with "1152a1a"
@OP
Here you declare a char arrays.
So receivedChars become a pointer to the first element in your array.
So you cannot do:
receivedChars == “11521a1” in your if statement.
Thanks
great, thank you both very much.
still having a very much related question, how can I achive that the routine mentioned by GolamMostafa is only performed if a new string receivedChars has arrived. In other words something like.
Thanks a lot
//Variable definition:
char previous_receivedChars[numChars]=receivedChars; //not working
void setup
previous_receivedChars=(receivedChars); //initialization of arrays to equal value
void loop(
 //compare string (Serial input) not equal to previous sting (previous serial input -> input changed
 bool n = strcmp(receivedChars, previous_receivedChar);
 if( n != 0)
   if( n == 0)
      //strings are equal, do something
@OP
Recommend to use the string type, more convenient for what you want to achieve.
You can store the incoming data into a string.
String class has already some built in methods you can use.
For more information, look on Arduino IDE samples under string
