Good evening, I'm having a small problem with the argument that happened to the thread and I would like to know how to solve it since I have searched all the internet forums and I can't find an answer, the code must print the variable in an array of de leds, but a problem is generated and it is that the argument when I try to read it as a char pointer gives a value of zero, but when I print the value as such of the char if it has the corresponding value, I would appreciate a small solution for this problem.
//Librerias
#include <Arduino.h>
#include "Wire.h"
#include "RTClib.h"
#include <MD_MAX72xx.h>
#include <SPI.h>
//Blinking rate in milliseconds
const portTickType TIMESTOP=1;
const portTickType TIMETAX=1;
const portTickType TIMERTC=1;
const portTickType TIMEREFREHS=1;
//Defines
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 4
#define CHAR_SPACING 1
//Pines
#define CLK_PIN 18
#define DATA_PIN 23
#define CS_PIN 5
MD_MAX72XX mx=MD_MAX72XX(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
RTC_DS1307 DS1307_RTC;
//Variables externas
char mess[4];
char Week_days[7][12]={"Domingo", "Lunes", "Martes", "Miercoles", "Jueves", "Viernes", "Sabado"};
char numbers[10]={48, 49, 50, 51, 52, 53, 54, 55, 56, 57};
bool flagDorN;
bool flagTorD;
bool banner;
int time_24s;
int distance=0;
int unitsNT=28;
int priceNT=2912;
int unitsT=52;
int priceT=5408;
int timeSeconds=0;
int cent;
int dec;
int unit;
int DMALHMS[7];
String dayT;
String hourT;
void setup(){
mx.begin();
if(!DS1307_RTC.begin()){
while(1);
DS1307_RTC.adjust(DateTime(F(__DATE__), F(__TIME__)));
//Variables internas
banner=1;
flagTorD=0;
//Hilos
xTaskCreate(Time24s, "Time24s", 1024, NULL, 1, NULL);
xTaskCreate(Taximeter, "Taximeter", 1024, NULL, 1, NULL);
xTaskCreate(Fun_DMALHMS, "Fun_DMALHMS", 2048, NULL, 1, NULL);
xTaskCreate(printTextUnitsT, "printTextUnitsT", 2048, (void*)&mess, 1, NULL);
void loop(){
delay(1);
void Time24s(void* args){
while(true){
if(flagTorD==0){
time_24s=time_24s+1;
vTaskDelay(TIMESTOP);
void Taximeter(void* args){
while(true){
if(banner==1){
if(DMALHMS[3]==0 || 20<=DMALHMS[4] || DMALHMS[4]<=5){
cent=unitsT/100;
dec=(unitsT-(cent*100))/10;
unit=(unitsT-(cent*100+dec*10));
for(int i=0; i<=9; i++){
if(i==cent){
mess[0]=char(numbers[i]);
if(i==dec){
mess[1]=char(numbers[i]);
if(i==unit){
mess[2]=char(numbers[i]);
mess[3]='\0';
if(time_24s==24000){
time_24s=0;
Serial.println(dayT);
Serial.println(hourT);
vTaskDelay(TIMETAX);
void Fun_DMALHMS(void* args){
while(true){
DateTime now=DS1307_RTC.now();
DMALHMS[0]=now.day();
DMALHMS[1]=now.month();
DMALHMS[2]=now.year();
DMALHMS[3]=now.dayOfTheWeek();
DMALHMS[4]=now.hour();
DMALHMS[5]=now.minute();
DMALHMS[6]=now.second();
dayT=String(DMALHMS[0])+"/"+String(DMALHMS[1])+"/"+String(DMALHMS[2]);
hourT=String(DMALHMS[4])+":"+String(DMALHMS[5])+":"+String(DMALHMS[6]);
vTaskDelay(TIMERTC);
void printTextUnitsT(void *args){
while(true){
char *vars=(char*)args;
Serial.print("(char*)args ");
Serial.println((char*)args);
Serial.print("*(char*)args ");
Serial.println(*(char*)args);
uint8_t state=0;
uint8_t curLen;
uint16_t showLen;
uint8_t cBuf[8];
int16_t col=(((uint8_t(MAX_DEVICES-1) + 1) * COL_SIZE)-1)-7;
mx.control(uint8_t(0), uint8_t(MAX_DEVICES-1), MD_MAX72XX::UPDATE, MD_MAX72XX::OFF);
do{
switch(state){
case 0:
if((*vars)=='\0'){
showLen=col-(uint8_t(MAX_DEVICES-1)*COL_SIZE);
state=2;
showLen=mx.getChar((*vars), sizeof(cBuf)/sizeof(cBuf[0]), cBuf);
curLen=0;
state++;
case 1:
mx.setColumn(col--, cBuf[curLen++]);
if (curLen==showLen){
showLen=CHAR_SPACING;
state=2;
case 2:
curLen=0;
state++;
case 3:
mx.setColumn(col--, 0);
curLen++;
if(curLen==showLen)
state=0;
default:
col=-1;
}while(col>=(uint8_t(0)*COL_SIZE));
mx.control(uint8_t(0), uint8_t(MAX_DEVICES-1), MD_MAX72XX::UPDATE, MD_MAX72XX::ON);
vTaskDelay(TIMEREFREHS);
Try a way of converting a void* to a char* char vars=malloc(sizeof(char *args)).
