Char to Hex Add 00
Hello ,
I need to add 00 to each character in a message and then write them as a byte in HEX:
68 07 01 01 00 00 00 0A 09 00 00 65 31 00 32 00 33 00 10
31 00 32 00 33 00 = Text "123"
00 0A = The length of the total payload "09 00 00 65 31 00 32 00 33 00"
I am not familiar with C, how can i char msgArray[] = "123"; add the 00 after each char and calculate the length of the payload?
I have tried the serial.write and this works when sending each byte separately but i want a function to enter the the text msgArray .
Any help is appreciated.
You could use a simple for loop and "strlen(msgArray)"
You could start with this:
char msgArray[30];
byte value = 123;
sprintf(msgArray,"%02x",value);  //format in ASCII hex
Not clear what you mean by the above. Those two representations are not the same.
char msgArray[] = "123" is the same as
char msgArray[] = {0x31,0x32,0x33,0x00}
Please give a better example of what you want to do. The original post is contradictory and confusing.
Maybe this will help
const char msgArray[] = "123";
char output[30]={0};
byte j=0;  //output index
for (byte i=0; i<strlen(msgArray); i++) {
output[j++]=msgArray[i];
output[j++]=0;
byte output_len=j--; //length of output array
arrayTrans
The above requirements can be made by the following codes:
char srcA[] = {'1', '2', '3'};
char desA[6];
  for(int i = 0, j = 0; i<3; i++, j++)  //building new array
    desA[j++] = srcA[i];
    desA[j] = '\0';
  for(int i = 0; i<sizeof desA; i++) //displaying contents of the new array
    byte y = desA[i];
    if(y < 0x10)
      Serial.print('0');
    Serial.print(desA[i], HEX);
void loop() {}
Output:
310032003300
Thanks
Instead of serial.print how can I make an array that i can use with with serial.write as hex(byte)
Did you see post #4, which does exactly what you asked?
Thanks, it has been a long time since i used Arduino and C,more than 10 years.
Will try it tomorrow , goodnight.
Given:
What do you expect to see on Serial Monitor if the following code is executed:
Serial.write(srcA);
A somewhat cryptic method that relies upon the processor storing integers little-endian.
char srcA[] = "123";
void setup(){
  uint16_t dest[strlen(srcA)] = {0};
  for (size_t i = 0; i < strlen(srcA); i++){
    dest[i] = srcA[i];
  Serial.write((byte*)dest, sizeof(dest));
  byte* b = (byte*)dest;
  for (size_t i = 0; i < sizeof(dest); i++){
    if (*b < 16) Serial.print('0');
    Serial.print(*b, HEX);
    b++;
    Serial.print(' ');
void loop(){
Is the above declaration same as the following?
Trick question :joy:
Roughly equivalent, the first adds a terminating null, so you can use strlen() to get the size instead of sizeof() for the 2nd, but after copying to the destination array I was using the output has no difference.
