I could use some help. I have a design where a rechargeable battery and LED are connected (think flashlight) and I'd like to charge the battery while the LED is still on in a dock. The part I'm purchasing has the battery and LED directly attached to each other, so I can not separate out the battery from the LED.
I'm using a MS920SE battery - data sheet here: (https://www.sii.co.jp/en/me/files/2024/01/MicroBattery_E_20230330_rev05-security.pdf) The data sheet recommends constant voltage with a current limiting resistor in the charging circuit.
I've drawn the schematic here:
(note the voltage regulator is not shown, but would S-13R1 per the datasheet)
Based on testing, the light draws about 14 mA at 3.1V and the battery charging circuit should be limited to 5mA at 3.1 V.
My Take:
In order to ensure the battery remains at a constant current charge, I need to detect if the light is on or off (current sensor over a resistor to microprocessor). To sense if the light is on, I would use a transistor to add a resistor in parallel to enable ~19 mA to flow. If I sense the current at a lower current (<5mA), or higher current (~20mA+, potential short) I would remove the voltage to the transistor and limit the flow to 5mA. I'm also considering current-limiting diodes for this application instead of resistors.
Any recommendations?
(Side note, I would also appreciate an explanation as to why adding the LED seems to make the circuit act as a voltage divider. In the simulations, this seems to limit the voltage that the battery will charge to when the LED is on.)
