charlieplex code 4x4x4 rgb arduino nano code
Good day all,
i'm new to this Arduino IDE. I don't know how to change the animation for my "charlieplex code 4x4x4".
only 1 type of animation after i loaded the code. I did not change any in the code.
This is the one I used.
https://codeload.github.com/AsherGlick/Charliecube/legacy.zip/master
The only animation in my cube
https://www.youtube.com/watch?v=XEZweQlfYnA
Your code uses interrupts. Variables that are changed in interrupt service routines (ISR) and are shared with normal 'code' should be declared volatile.
Search your cubeplex.h for ISR(TIMER1_OVF_vect) . You will find
int animationTimer = 0;
int animationMax = 0;
ISR(TIMER1_OVF_vect) {
  animationTimer++;
  if (animationTimer == animationMax) {
    continuePattern = false;
    animationTimer=0;
Change the first two lines to
volatile int animationTimer = 0;
volatile int animationMax = 0;
Next find the declaration of continuePattern; the line looks like
bool continuePattern = false;
and change it to
volatile bool continuePattern = false;
Next search your code for ISR(TIMER2_OVF_vect). You will find
In there you will find
1)
  if (count > pwmm){
count is a local variable and the declaration does not need to be changed. pwmm is not local and probably needs to be changed.
Find the line that contains the declaration of pwmm;
int pwmm = 0;
and change it to
volatile int pwmm = 0;
2) There are a few more lines that change variables that are declared outside the ISR. Also find the lines
_frame_light * _cube__frame;
_frame_light * _cube_current_frame;
char * _cube_buffer;
and change them to
volatile _frame_light * _cube__frame;
volatile _frame_light * _cube_current_frame;
volatile char * _cube_buffer;
Give that a shot; if it does not solve it, I do not know.
