cheap advertising display
Hi guys, i'm working on an android project that send a video or image to a tablet that work only like a video player.
All work fine but now i need to reduce project costs and the tablet is very expensive.
is there a way to create a cheap display ( about 10") that works like a video player?
i need only the display, after i'll work to create a communication with the android app.
all suggestions are welcome!
Thanks
Maybe if you hung some numbers on "cheap" and "very expensive" . . ?
TheMemberFormerlyKnownAsAWOL:
and android tablet are about 150€
i need one with 20/30€, also something like this could be a solution
acronalb:
Check Innolux LCD panels (chinas model is cheaper ...)
Maybe this model if you can find it ...
Panel Brand : CHIMEI INNOLUX
Panel Model : SD101IA-01H
Panel Size : 10.1"
Panel Type : a-Si TFT-LCD , Assembly
Resolution : 1280(RGB)×800 , WXGA
or this 7" model : innolux-LCD 7.0 inch AT070TN94
Note: the connection interface maybe different (50pin parallel or LVDS)
This topic was automatically closed after 120 days. New replies are no longer allowed.
