This sketch allows the checking of the range of values you get from a Wii nunchuck plugged into a MP.
It was based on various conversations and code here.
It is interesting to note the NC range I got when it was moved violently.
Enjoy
Mark
PS be kind I should have learnt C 20 years ago, rather than last month...
Code for reading data from a Wii Motion plus device connected to a Nunchuck
The purpose is to detect the maximum values and send them to the display.
Hardware Arduino with ATMega 168
Connections SCA to AD4 (Analog4) and SCL to AD5 (Analog5)
Code sources
8/9/2009 - by dimkasta @ www.kastaniotis.net
Adapted for use with the transistor-less switching code originally written by krulkip on
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1248889032/60
Calibration and utility code based on the code by duckhead
9/9/2009 - by dimkasta @ www.kastaniotis.net
Added Accelerometer calibration
Removed the casting to double and the multiplying with millis/sec from the cycle saving to further greately
increase the free time to ~1/50 in comparison to the reading time.
18/9/2009 - by Ardvark
Slow/fast bit reading fixed: Slow degree/sec scale value appears correct.
modified form a collection of contributions
19 May 2010
by Mark Beckett
In working my way through the various pieces of the software, in order to understand (and learn C)
It became apparent that a few conclusions were made, in regard to the MIN/MAX values of the Nunchuck
This little hack gives the capability of capturing the values.
It was interesting to note that if the device was moved violently, then the range was greater.
( I don't think its my maths doing it ...)
axMIN axMAX | ayMIN ayMAX | azMIN azMAX
Gentle 294 754 | 300 746 | 304 764
Violent 100 986 | 228 1018 | 76 796
Anyway thanks to all the people in the forum whom contributed to the makeup of the donor sketch.
Now if I could only get used the damn ; after each line
Mark Beckett
// TODO LIST - Known issues
// Learn C (20 years ago) so I can tidy it up.
// add something to check the Gyro MAX and MIN values.
// remove anything not needed if the above is not used.
#include <Wire.h>
boolean DataChanged = false;
uint8_t data[6]; // array to store arduino output
int cnt = 0;
int ledPin = 13;
int xID;
//wiibrew info seems to be incorrect with regards to scaling, see instead Xevel's comments: http://www.assembla.com/wiki/show/alicewiimotionplus/slow_and_fast_modes
static const int wmpSlowToDegreePerSec = 16; //when gyro speed 1, 16 units = 1°/s
static const int wmpFastToDegreePerSec = 4; //when gyro speed 0, 4 units = 0,25°/s
// Hardware identifiers. Polling data[5]&0x03 for present device
static const int NC = 0x00;
static const int MP = 0x02;
int currentDevice;
// WM+ state variables - if true, then in slow (high res) mode
boolean slowYaw = 0;
boolean slowPitch = 0;
boolean slowRoll = 0;
int rollScale;
int pitchScale;
int yawScale;
// Initial gyro values (- yaw0 etc)
int yaw = 0;
int pitch = 0;
int roll = 0;
// accelerometer values
int ax_m = 0;
int ay_m = 0;
int az_m = 0;
int axMIN = 500;
int axMAX = 0;
int ayMIN = 500;
int ayMAX = 0;
int azMIN = 500;
int azMAX = 0;
double x;
double y;
double z;
void setup ()
Serial.begin (115200);
Wire.begin(); // initialize i2c
// we need to switch the TWI speed, because the nunchuck uses Fast-TWI
// Not sure I could actually detect any difference.
TWBR = ((16000000 / 400000L) - 16) / 2;
initializeSensors();
void send_zero ()
delay(5); //5 mS delay between reads see (http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1259091426/109#109)
Wire.beginTransmission(0x52);
Wire.send(0x00);
Wire.endTransmission();
delayMicroseconds(200); //200 microseconds delay between send zero and read see (http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1259091426/109#109)
} //stitch
