chips ain't chattin'
Hi there. I am trying to create a very simple(at first) setup using two arduino's and a couple of rf units(transmitter and receiver)
to turn an led on remotely. i am using the virtual wire library to achieve my goal.i have managed to get them both talking using the example code which came with the library.
i have now modified the code so that i can send data from one arduino from serial monitor. the receiver seems to only intermittently 'catch' the data however and the if statement control which i have implemented doesn't work at all. if you could have a look at my code and offer some suggestions i would be very grateful. please forgive my ignorance, i am new to this jive.
transmitter code:
#include <VirtualWire.h>
    Serial.begin(9600);	  // Debugging only
    // Initialise the IO and ISR
    vw_set_tx_pin(12);//connected to the data pin of the rf transmitter
    vw_set_ptt_inverted(true); // Required for DR3100
    vw_setup(4000);	 // Bits per sec
    if (Serial.available() > 0) {
    const char* msg = (const char*) Serial.read();
    digitalWrite(13, true); // Flash a light to show transmitting
    vw_send((uint8_t *)msg, strlen(msg));
    vw_wait_tx(); // Wait until the whole message is gone
    digitalWrite(13, false);
receiver code:
/const int ledPin = 13, ledPin1 = 11, ledPin2 = 10; // the pin that the LED is attached to
boolean counter_1 = 0, counter_2 = 0, counter_3 = 0; //variables to keep track of the led state
    // initialize the LED pins as an output:
    pinMode(ledPin, OUTPUT);
    pinMode(ledPin1, OUTPUT);
    pinMode(ledPin2, OUTPUT);
    vw_set_rx_pin(12);
    vw_rx_start();       // Start the receiver PLL running
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
        //digitalWrite(13, true); // Flash a light to show received good message
	// Message with a good checksum received, dump it.
            int i;
            if (buf[i] == '1')
               digitalWrite(ledPin,HIGH);
Serial.read returns a single character as an int.
Casting an int to a char pointer isn't sensible.
What are you trying to do?
i want to use the data as 'commands' so that i can switch different pins on an off and i want to display messages on an lcd screen.
OK. You have our permission.
Any advice at all?
gonadgranny:
Any advice at all?
Stop casting the value returned by Serial.read to something that it's not. Here's a scenario,
your Serial.read returns a value of 'A' (so that's 65). Why would you then want to look at what's stored at memory address 65?
As AWOL has pointed out, casting it to a pointer is totally wrong.
"gonadgranny" and "dannygrogan"
Merely anagrams who both happen to be Sky Broadband customers and both seem to be called Danny, or sock-puppets?
Just askin'
KenF:
reason i tried that out is because vw_send wont accept an integer. i get 'invalid conversion from int to const char*' so i thought that perhaps if i did the conversion outside of the method(and please again forgive me if i am not making utter sense here, i am working with my limited knowledge on this subject) then it might work. turns out it did. or at least it compiled.
AWOL:
Just askin'
yes they are both me. it was not intentional, i forgot i already had an account set up here.
gonadgranny:
If someone demands payment by credit card but you only have hard cash, you wouldn't just pass them the serial number of a banknote and expect that to be accepted as a credit card would you? You'd put the cash into a credit card account and pass the credit card details.
Likewise, if you have a char but your function wants a pointer to a char array, you need to put that char into a char array and pass your function the pointer to that array.
But, since you have an int, and the function expects a byte array, you have a problem. Now, it's not insurmountable, and not even really difficult.
A char and a byte are the same size, and can be cast to each other. The same holds trur of char and byte arrays. So, if you have a char array, say one populated by sprintf() from the int, you could cast that as a byte array (or byte pointer) so that vw_send() would like it.
