Avoid the 0.25 ohm one (CSD23381F4), any of the others will be fine from what I can see.
The threshold voltages and current specs are irrelevant,
go by the Rds(on) specs - both for gate-source voltage
supported and on-resistance. Calculate the voltage drop
and power dissipation (IR, I^2 R) and check they are OK.
The threshold voltages catch a lot of people out, they are
not the voltage for the device being on, but for it being off
Current figures usually are thermal limits anyway, which
you calculate from Rds(on) anyway.
You might want to avoid the 8V one just as its the lowest
Vds spec of the bunch - just in case there are spikes around.
