Circuit for USB power detection & measuring battery voltage
Please, confirm or fix this schematic. I want to perform detection of USB power presence and battery voltage.
  • [Power Sensor] goes to ADS1115 connected via I2C. R6 & R8 is voltage divider.
  • [A0] goes to Wemos D1 Mini A0 pin
I don't see anything that measures battery voltage. But I guess it detects that the battery hasn't shut down completely.
Sorry, fixed
I think the ESP8266 analog input only works between zero and 1 volt. If that's right, you'll need to divide down the battery voltage from a maximum 4.2V to 1.0V. Or you could pipe that line into the ADS1115 instead.
Nice schematic. Shame it doesnt show the bits you are asking about (the ads1115 and Wemos)
or have links for data sheets for the bits it does show?
Here it is: PetNet Feeder Revival - EasyEDA open source hardware lab
Does USB power go here?
Yes
Everything looks OK.
The only thing that I would change is to also connect pin 4 of the MT3608 module to ground.
