.clang-format file being ignored
In the process of setting up a new PC following a hard disk crash I have reinstalled IDE 2.3.3 which was the version previously used
Turning my attention to Auto Formatting, I put the previously used .clang-format file in the .arduinoIDE folder but it seems to be being ignored. When copied to the same folder as a small test sketch it is also ignored
I can't help feeling that I have missed something obvious, but I can't for the life of me see what. Before anyone asks, the file really is named .clang-format and hasn't gained a spurious .txt extension due to Windows propensity to hide extensions
The only thing that I can think of is that the new PC is using Windows 11 whereas the previous one used Windows 10
Bright ideas anyone ?
For the sake of completeness, here is the contents my .clang-format file
#default format originally from
#https://docs.arduino.cc/software/ide-v2/tutorials/ide-v2-customize-auto-formatter
Original lines changed commented with bbb
Language: Cpp
# LLVM is the default style setting, used when a configuration option is not set here
BasedOnStyle: LLVM
AccessModifierOffset: -2
AlignAfterOpenBracket: Align
AlignConsecutiveAssignments: false
AlignConsecutiveBitFields: false
AlignConsecutiveDeclarations: false
AlignConsecutiveMacros: false
AlignEscapedNewlines: DontAlign
AlignOperands: Align
AlignTrailingComments: true
AllowAllArgumentsOnNextLine: true
AllowAllConstructorInitializersOnNextLine: true
AllowAllParametersOfDeclarationOnNextLine: true
AllowShortBlocksOnASingleLine: Always
AllowShortCaseLabelsOnASingleLine: true
AllowShortEnumsOnASingleLine: true
AllowShortFunctionsOnASingleLine: Empty
AllowShortIfStatementsOnASingleLine: Always
AllowShortLambdasOnASingleLine: Empty
AllowShortLoopsOnASingleLine: true
AlwaysBreakAfterDefinitionReturnType: None
AlwaysBreakAfterReturnType: None
AlwaysBreakBeforeMultilineStrings: false
AlwaysBreakTemplateDeclarations: No
BinPackArguments: true
BinPackParameters: true
# Only used when "BreakBeforeBraces" set to "Custom"
BraceWrapping:
  AfterCaseLabel: false
  AfterClass: false
  AfterControlStatement: Never
  AfterEnum: false
  AfterFunction: false
  AfterNamespace: false
  #AfterObjCDeclaration:
  AfterStruct: false
  AfterUnion: false
  AfterExternBlock: false
  BeforeCatch: false
  BeforeElse: false
  BeforeLambdaBody: false
  BeforeWhile: false
  IndentBraces: false
  SplitEmptyFunction: false
  SplitEmptyRecord: false
  SplitEmptyNamespace: false
# Java-specific
#BreakAfterJavaFieldAnnotations:
BreakBeforeBinaryOperators: NonAssignment
# bbb BreakBeforeBraces: Attach
BreakBeforeBraces: Allman
BreakBeforeTernaryOperators: true
BreakConstructorInitializers: BeforeColon
BreakInheritanceList: BeforeColon
BreakStringLiterals: false
ColumnLimit: 0
# "" matches none
CommentPragmas: ""
CompactNamespaces: false
ConstructorInitializerAllOnOneLineOrOnePerLine: true
ConstructorInitializerIndentWidth: 2
ContinuationIndentWidth: 2
Cpp11BracedListStyle: false
DeriveLineEnding: true
DerivePointerAlignment: true
DisableFormat: false
# Docs say "Do not use this in config files". The default (LLVM 11.0.1) is "false".
#ExperimentalAutoDetectBinPacking:
FixNamespaceComments: false
ForEachMacros: []
IncludeBlocks: Preserve
IncludeCategories: []
# "" matches none
IncludeIsMainRegex: ""
IncludeIsMainSourceRegex: ""
IndentCaseBlocks: true
IndentCaseLabels: true
IndentExternBlock: Indent
IndentGotoLabels: false
IndentPPDirectives: None
IndentWidth: 2
IndentWrappedFunctionNames: false
InsertTrailingCommas: None
# Java-specific
#JavaImportGroups:
# JavaScript-specific
#JavaScriptQuotes:
#JavaScriptWrapImports
# bbb KeepEmptyLinesAtTheStartOfBlocks: true
KeepEmptyLinesAtTheStartOfBlocks: false
MacroBlockBegin: ""
MacroBlockEnd: ""
# Set to a large number to effectively disable
# bbb MaxEmptyLinesToKeep: 10000000
MaxEmptyLinesToKeep: 0
NamespaceIndentation: None
NamespaceMacros: []
# Objective C-specific
#ObjCBinPackProtocolList:
#ObjCBlockIndentWidth:
#ObjCBreakBeforeNestedBlockParam:
#ObjCSpaceAfterProperty:
#ObjCSpaceBeforeProtocolList
PenaltyBreakAssignment: 1
PenaltyBreakBeforeFirstCallParameter: 1
PenaltyBreakComment: 1
PenaltyBreakFirstLessLess: 1
PenaltyBreakString: 1
PenaltyBreakTemplateDeclaration: 1
PenaltyExcessCharacter: 1
PenaltyReturnTypeOnItsOwnLine: 1
# Used as a fallback if alignment style can't be detected from code (DerivePointerAlignment: true)
PointerAlignment: Right
RawStringFormats: []
ReflowComments: false
SortIncludes: false
SortUsingDeclarations: false
SpaceAfterCStyleCast: false
SpaceAfterLogicalNot: false
SpaceAfterTemplateKeyword: false
SpaceBeforeAssignmentOperators: true
SpaceBeforeCpp11BracedList: false
SpaceBeforeCtorInitializerColon: true
SpaceBeforeInheritanceColon: true
SpaceBeforeParens: ControlStatements
SpaceBeforeRangeBasedForLoopColon: true
SpaceBeforeSquareBrackets: false
SpaceInEmptyBlock: false
SpaceInEmptyParentheses: false
SpacesBeforeTrailingComments: 2
SpacesInAngles: false
SpacesInCStyleCastParentheses: false
SpacesInConditionalStatement: false
SpacesInContainerLiterals: false
SpacesInParentheses: false
SpacesInSquareBrackets: false
Standard: Auto
StatementMacros: []
TabWidth: 2
TypenameMacros: []
# Default to LF if line endings can't be detected from the content (DeriveLineEnding).
UseCRLF: false
UseTab: Never
WhitespaceSensitiveMacros: []
If this line is in your real file and not just added for the forum, that is the cause of your problem. Comment it out.
I get these errors in the log
Language'
Error reading \Users\bugge\.arduinoIDE\.clang-format: invalid argument
    at ChildProcess.<anonymous> (C:\Users\bugge\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:788280)
    at ChildProcess.emit (node:events:514:28)
    at Process.onexit (node:internal/child_process:291:12)
After commenting it out, it seems to work (at least BreakBeforeBraces: Allman did its job).
Thanks for spotting that. All OK now
As I suspected :grinning:
Where and how can I see the log ?
C:\Users\yourUsername\AppData\Roaming\Arduino IDE
You can also test using http://clang-format-configurator.site/; I did try to load your file there first and it told me that something was wrong (I can't remember what it exactly complained about).
Thanks
