I am working on a security access point. I would like it to read an RFID and then enter my OTP. I have it kinda working. The OTP works great and it will scan the the RFID and hold in the buffer. It will not clear the buffer and will not run this section. I have included a full copy of the code as well.
if(myserial.available() > 0) {
BadgeRead[Index] = myserial.read();
if (Badge[Index] == BadgeRead[Index])
digitalWrite (powerPin, LED_ON);
lcd.setCursor(0, 2);
lcd.print("Good RFID");
#include <Arduino.h>
#include <RTClib.h>
#include <DS3231.h>
#include <Wire.h>
#include <RTClib.h>
#include <Time.h>
#include <sha1.h>
#include <TOTP.h>
#include <i2ckeypad.h>
#include <SoftwareSerial.h>
DS3231 RTC;
LiquidCrystal_I2C lcd(0x27,20,4);
SoftwareSerial myserial(10, 11); // RX, TX
#define DS3231_I2C_ADDRESS 0x68
#define PCF8574_ADDR 0x20
#define ROWS 4
#define COLS 4
#define LED_ON LOW
#define LED_OFF HIGH
#define powerPin 3
#define passPin 4
#define failPin 2
#define relayPin 5
int z = 0;
int i = 0; //----- JUNK VARIABLE -----
long Idle_Count = 0; //----- IDLE TIME COUNTER -----
int Index = 0; //----- COUNTS EACH BYTE READ FROM RFID MODULE -----
int BadgeRead[14]; //----- STORES BYTES READ FROM RFID MODULE INTO AN ARRAY -----
i2ckeypad kpd = i2ckeypad(PCF8574_ADDR, ROWS, COLS);
// shared secret
uint8_t hmacKey[] = {0x34, 0x67, 0x78, 0x71, 0x40, 0x6d, 0x5a, 0x3b, 0x7e, 0x4e};
TOTP totp = TOTP(hmacKey, 10);
char totpCode[7];
char inputCode[7];
int inputCode_idx;
int Badge[14] = {2, 48, 48, 48, 48, 67, 70, 55, 70, 56, 70, 51, 70, 3};// BADGE - 0013598607 207,32655
lcd.begin();
lcd.backlight();
myserial.begin(9600);
pinMode(powerPin, OUTPUT);
pinMode(passPin, OUTPUT);
pinMode(failPin, OUTPUT);
pinMode(relayPin, OUTPUT);
digitalWrite(failPin, LED_OFF);
digitalWrite(passPin, LED_OFF);
digitalWrite(powerPin, LED_OFF);
digitalWrite(relayPin, LOW);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("One Time Password");
lcd.setCursor(0, 1);
lcd.print("Enter your Code");
Wire.begin();
kpd.init();
// reset input buffer index
inputCode_idx = 0;
char key = kpd.get_key();
// a key was pressed
if (key != '\0') {
// # resets the input buffer
if(key == '#') {
lcd.print("Clear Buffer");
inputCode_idx = 0;
memset(&BadgeRead, 0, 14);
delay (1000);
lcd.clear();
else {
// save key value in input buffer
inputCode[inputCode_idx++] = key;
// if the buffer is full, add string terminator, reset the index
// get the actual TOTP code and compare to the buffer's content
if(inputCode_idx == 6) {
inputCode[inputCode_idx] = '\0';
inputCode_idx = 0;
// lcd.setCursor(0, 2);
// lcd.print("Code Entered: ");
// lcd.setCursor(14, 2);
// lcd.print(inputCode);
RTCDateTime now = RTC.getDateTime();
unsigned long GMT = now.unixtime;
strcpy(totpCode,totp.getCode(GMT));
//----- READ FROM RFID MODULE -----
// code is ok :)
if(strcmp(inputCode, totpCode) == 0) {
digitalWrite(passPin, LED_ON);
digitalWrite(relayPin, HIGH);
lcd.setCursor(0, 3);
lcd.print("Code ok");
delay(4000);
//digitalWrite(powerPin, LED_ON);
lcd.clear();
// code is wrong :(
digitalWrite(failPin, LED_ON);
lcd.print("Correct Code: ");
lcd.setCursor(14, 3);
lcd.print(totpCode);
delay(4000);
lcd.clear();
lcd.print("Bad RFID");
delay (4000);
lcd.clear();
