My arduino client is sending http request to my server every minutes. (Actually there are two http request in every minutes- one to get some data and one to execute a php script. I have been getting a warning message in mysql. After hours of searching I came to a conclusion that client.stop() at the end of the http request is not closing the connection. (That is the basic reason for the warning). I have seen that some people reported the same error before. Any suggestions please
//error message. it goes on ever minutes- 2 warnings per minutes- 2 http requests!
2019-08-27 10:35:26 32 [Warning] Aborted connection 32 to db: 'unconnected' user: 'root' host: '192.168.xx.xxx' (Got an error reading communication packets)
2019-08-27 10:35:26 35 [Warning] Aborted connection 35 to db: 'unconnected' user: 'root' host: '192.168.xx.xxx' (Got an error reading communication packets)
2019-08-27 10:36:26 36 [Warning] Aborted connection 36 to db: 'unconnected' user: 'root' host: '192.168.xx.xxx' (Got an error reading communication packets)
2019-08-27 10:36:26 39 [Warning] Aborted connection 39 to db: 'unconnected' user: 'root' host: '192.168.xx.xxx' (Got an error reading communication packets)
dayDreamer1013:
I used the program from https://arduinojson.org/v5/example/http-client/
add client.stop() to all 'exits'. now it si closed only on sucess
it will close the connexion but a client is considered connected if the connection has been closed but there is still unread data. Just empty the stream before closing:
while (client.available()) client.read();
client.stop();
J-M-L:
client.stop();
or faster
while (client.read() != -1);
client.stop();
connected() returns true if data are available, but it has no implication for stop()
It still uses “an instance” - not sure how they are garbage collected / cleaned up or if there is a cap to the number of client that can hang around (would need to check source code one of those days)
J-M-L:
after stop() the data are not available.
the buffers are in the Wiznet chip
