Clock not keeping time
Hi, I'm new to programming bought an Arduino to create some real-world projects.
I'm trying to code a clock with just a UNO R3 started kit. I'm using the millie() function to keep time. However, after 10 minutes, there is a delay of about a second.
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int seconds = 0;
int minutes = 0;
int hours = 0;
unsigned long tSeconds = 1000;
unsigned long recTime = 0;
  int hours = 0;
  lcd.begin(16, 2);
  lcd.print("Clock");
  lcd.setCursor(8,1);
  lcd.print("  :  :  ");
  lcd.setCursor(0, 1);
  lcd.print(millis()/1000);
  lcd.setCursor(14, 1);
   if (seconds < 10){
    lcd.print("0");
  lcd.print(seconds);
lcd.setCursor(11, 1);
  if (minutes < 10){
    lcd.print("0");
  lcd.print(minutes);
  lcd.setCursor(8, 1);
  if (hours < 10){
    lcd.print("0");
  lcd.print(hours);
  if (millis() - recTime >= tSeconds){
    seconds += 1;
    recTime = millis();
  if (seconds >= 60){
    minutes += 1;
    seconds = 0;
  if (minutes >= 60){
    hours += 1;
    minutes = 0;
  if (hours >= 24){
    hours = 0;
Your code is unnecessarily complex. Just grab the current value of millis and calculate how many hours, minutes and seconds it is.
This is risky:
    seconds += 1;
    recTime = millis();
millis may tick over while you're incrementing seconds and now you've got time unaccounted for.
Read all about millis().
In any case a clock built around millis() will not be very accurate , ideally use something like a DS3231
