Cloud reports webhook inactive when it is active
I created a google apps script and linked it to an arduino cloud thing as a webhook. The Cloud dashboard reports the webhook as inactive even though I can manually send requests to the url.
Code:
* Copyright 2022 Peter Bendel
* copied (and then modified) from: https://github.com/arduino/arduino-iot-google-sheet-script/blob/master/Code.gs
* Copyright 2018 ARDUINO SA (http://www.arduino.cc/)
* This file is part of arduino-iot-google-sheet-script.
* Copyright (c) 2019
* Authors: Marco Passarello
* This software is released under:
* The GNU General Public License, which covers the main part of
* arduino-iot-google-sheet-script
* The terms of this license can be found at:
* https://www.gnu.org/licenses/gpl-3.0.en.html
* You can be released from the requirements of the above licenses by purchasing
* a commercial license. Buying such a license is mandatory if you want to modify or
* otherwise use the software for commercial activities involving the Arduino
* software without disclosing the source code of your own applications. To purchase
* a commercial license, send an email to license@arduino.cc.
// get active spreadsheet
var ss = SpreadsheetApp.getActiveSpreadsheet();
// get sheet named ArduinoIOTCloudSensorData
var sheet = ss.getSheetByName('RawData');
var MAX_ROWS = 1440;     // max number of data rows to display
// 1 day * 60 (per hour) * 24 hours
var HEADER_ROW = 1;     // row index of header
var TIMESTAMP_COL = 1;  // column index of the timestamp column
var INTERVAL_IN_SECONDS = 60;  // 1 minute
function doGet(e) {
  return ContentService.createTextOutput("Webhook is up.");
function doPost(e) {
  var cloudData = JSON.parse(e.postData.contents); // this is a json object containing all info coming from IoT Cloud
  //var webhook_id = cloudData.webhook_id; // really not using these three
  //var device_id = cloudData.device_id;
  //var thing_id = cloudData.thing_id;
  var values = cloudData.values; // this is an array of json objects
  // store names and values from the values array
  // just for simplicity
  var incLength = values.length;
  var incNames = [];
  var incValues = [];
  for (var i = 0; i < incLength; i++) {
    incNames[i] = values[i].name;
    incValues[i] = values[i].value;
  // read timestamp of incoming message
  var timestamp = values[0].updated_at;          // format: yyyy-MM-ddTHH:mm:ss.mmmZ
  var date = new Date(Date.parse(timestamp));
    // this section write property names
    sheet.getRange(HEADER_ROW, 1).setValue('timestamp');
      var lastCol = sheet.getLastColumn(); // at the very beginning this should return 1 // second cycle -> it is 2
      if (lastCol == 1) {
        sheet.getRange(HEADER_ROW, lastCol + 1).setValue(incNames[i]);
        // check if the name is already in header
        var found = 0;
        for (var col = 2; col <= lastCol; col++) {
          if (sheet.getRange(HEADER_ROW, col).getValue() == incNames[i]) {
            found = 1;
        if (found == 0) {
          sheet.getRange(HEADER_ROW, lastCol+1).setValue(incNames[i]);
    // redefine last coloumn and last row since new names could have been added
    var lastRow = sheet.getLastRow();
    // delete last row to maintain constant the total number of rows
    if (lastRow > MAX_ROWS + HEADER_ROW - 1) {
      sheet.deleteRow(lastRow);
  if (lastRow > 1) { // this is not the first time - check if we have a new date
    // read last date written and only if we are at least
    var lastDate = sheet.getRange(HEADER_ROW+1, TIMESTAMP_COL).getValue();
    // only if enough time has passed after last reporting interval add a new row
    if (date.getTime() - lastDate.getTime() > (INTERVAL_IN_SECONDS*1000)) {
      // insert next row after header row
      sheet.insertRowAfter(HEADER_ROW);
      // write the timestamp only once per interval
      sheet.getRange(HEADER_ROW+1, TIMESTAMP_COL).setValue(date).setNumberFormat("yyyy-MM-dd HH:mm:ss");
    // insert first row after header row
    // reset style of the new row, otherwise it will inherit the style of the header row
    var range = sheet.getRange('A2:Z2');
    //range.setBackground('#ffffff');
    range.setFontColor('#000000');
    range.setFontSize(10);
    range.setFontWeight('normal');
    // write values in the respective columns
    for (var col = 1+TIMESTAMP_COL; col <= lastCol; col++) {
        var currentName = sheet.getRange(HEADER_ROW, col).getValue();
        if (currentName == incNames[i]) {
          // turn boolean values into 0/1, otherwise google sheets interprets them as labels in the graph
          if (incValues[i] == true) {
            incValues[i] = 1;
          } else if (incValues[i] == false) {
            incValues[i] = 0;
          sheet.getRange(HEADER_ROW+1, col).setValue(incValues[i]);
    return ContentService.createTextOutput("OK");
Hello @arduinoclouderino,
Could you give me the thing id?
A webhook can become inactive if that endpoint is not reachable for a while.
Thanks.
Stefano
Over on the Arduino Discord server, @arduinoclouderino reported that they were already able to resolve the problem with the information provided on another forum topic:
