CNC Homing Help?
I'm having trouble setting up Homing on my MPCNC.
I'm using Arduino Uno with CNC Shield and CNCjs as a Gcode Sender and have uploaded GRBL 1.1h
All connections are made to the CNC Shield.
GRBL codes for auto homeing are enabled, when the process starts it lowers the Z-axis and limit switch is activated but the machine does not stop.
Any help or direction to a link would help.
Thanks
There are two seperate settings for homing.
I always recommend reading this page to start with.
See $5, $20, $21, $22 and also the explanations for them.
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
I would remove/disconnect the drive couplers before testing homing. If you crash an axis it can cause
expensive mechanical damage. Just simulate the movements by hand-operating the limit-switches and check the motors stop.
Once you have it doing the right thing re-couple the motors and check again with hand over the e-stop switch...
