Im currently building a new CNC machine and somehow I cant get the steppers work correctly.
Have a look at this video:
I send a simple commands to the motor. Z0 and Z5. The motor is very loud and as you see in thr video, the motor makes a stop for a short period of time before it finishes the motion.
The shield is running GRBL.
Its not a mechanical problem as the leadscrew moves without problems.
What am Im doing wrong? I tested the coils of the motor and the wiring seems to be correct.
I dont think its a mechanical problem because have a look:
There is no coupling at all and the problem persists. Maybe the drivers are broken? Tried all 4 and everytime the same. Also tried another stepper. Same here.
Acceleration settings: what could go wrong here? I have 10 mm/s here.
Have you seen the video two posts above for g1 z50? For the time the motor spins I cant stop it, no. It stays still for a few seconds by its own before it finishes the motion.
I can't find a maximum rated speed but from the sound and movement in the video it looks like you are trying to move it faster than it can move. Try setting the maximum speed lower. F50 (50 steps per minute?) works. Try doubling the speed (100, 200, 400, 800...) until the problem comes back. Then you know that the maximum speed is between the last two speeds.
