Code beat me again, 7 segment this time
So, i managed to do this many years ago, BUT, now that i started doing again (nope, didn't take copy of that previously working code....)
this for some reason won't work at least the way it should
Basic 2-digit timer, but the trouble currently is that other digit won't go on, even though i'm quite sure i told it to do so. However, when i drive them as separatery, i mean as 1 digit, they work as intened. What bothers me is that they won't work as multiplexing/synchronously, if you get my meaning. those codes all over the internet didn't help either, didn't find that thing that causes this, there is blanking supposedly between digits. But, hopefully you guys could shep some light....port manipulation might be overkill, but i recently started doing codes with it, shoudln't be issue....
and, i use 4543 bcd-7 segment driver, if that makes any difference. i have a feeling it is something small but well, significant error in my code....
int const t =100;
int count;
  //Serial.begin(9600);       //debugging
  DDRD = DDRD | B11111100;    //Data direction register D, 0=input, 1=output: pins 4-7 output
  DDRB = B00000011;           // 8, 9 outputs
PORTD = B00000000;                 //display 0
PORTB = B00000001;                 //turn on digit 1
picknumber(count / 1 % 10);
delayMicroseconds(10);
PORTB = B00000010;                  //turn on digit 2
picknumber(count / 10 % 10);
  delay(t);                         //increment delay 0.1s, resolution is 0.1s
count++;                           //increment
//Serial.println(count);            //debugging
void picknumber( int count)
  switch (count)
  //case 0: zero(); break;
  case 1:PORTD=B00010000; break;            //1
  case 2:PORTD=B01000000; break;            //2
  case 3:PORTD=B01010000; break;            //3
  case 4:PORTD=B10000000; break;            //4
  case 5:PORTD=B10010000; break;            //5
  case 6:PORTD=B11000000; break;            //6
  case 7:PORTD=B11010000; break;            //7
  case 8:PORTD=B00100000; break;            //8
  case 9:PORTD=B00110000; break;            //9
  default: B00000000; break;                //0
now then, this was silly thread, i confused millis to micros and that was causing the bug, first digit simply was too fast hehe....sorry!
