Good day everyone, can anyone help me with the bug i have?
#include <TimerOne.h>
int a = 2;
int b = 3;
int c = 4;
int d = 5;
int e = 6;
int f = 7;
int g = 8;
int p = 9;
int A = 16;
int B = 17;
int C = 18;
int D = 19;
int E = 20;
int F = 21;
int G = 22;
int H = 23;
int P = 24;
int d4 = 10;
int d3 = 11;
int d2 = 12;
int d1 = 13;
int d8 = 25;
int d7 = 26;
int d6 = 27;
int d5 = 28;
int machineon = 30;
int machineoff = 31;
long n = 0;// n represents the value displayed on the LED display. For example, when n=0, 0000 is displayed. The maximum value is 9999.
long m = 0;
int x = 100;
int y = 100;
int del = 5;//Set del as 5; the value is the degree of fine tuning for the clock
int count = 0;//Set count=0. Here count is a count value that increases by 1 every 0.1 second, which means 1 second is counted when the value is 10
int count1 = 0;
int seconds=0,minutes=0,hours=0;
int add;
pinMode(d1, OUTPUT);
pinMode(d2, OUTPUT);
pinMode(d3, OUTPUT);
pinMode(d4, OUTPUT);
pinMode(a, OUTPUT);
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
pinMode(p, OUTPUT);
pinMode(d5, OUTPUT);
pinMode(d6, OUTPUT);
pinMode(d7, OUTPUT);
pinMode(d8, OUTPUT);
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, OUTPUT);
pinMode(D, OUTPUT);
pinMode(E, OUTPUT);
pinMode(F, OUTPUT);
pinMode(G, OUTPUT);
pinMode(P, OUTPUT);
Timer1.initialize(100000); // set a timer of length 100000 microseconds (or 0.1 sec - or 10Hz => the led will blink 5 times, 5 cycles of on-and-off, per second)
Timer1.attachInterrupt( add ); // attach the service routine here
void runtime();
void downtime();
void runtime()
void display1()
int digit_value_1;
int digit_value_2;
int digit_value_3;
int digit_value_4;
if (digitalRead(machineon) == HIGH)
// 1. Load number 1
digit_value_1 = seconds % 10;
digit_value_2 = (seconds / 10) % 10;
// 2. Load number 2
digit_value_3 = (minutes) % 10;
digit_value_4 = (minutes / 10) % 10;
//3. Update number to display
pickDigit(0);//Light up 7-segment display d1
pickNumber(digit_value_1);// get the value of thousand
delay(del);//delay 5ms
pickDigit(1);//Light up 7-segment display d2
pickNumber(digit_value_2);// get the value of hundred
pickDigit(2);//Light up 7-segment display d3
pickNumber(digit_value_3);//get the value of ten
pickDigit(3);//Light up 7-segment display d4
pickNumber(digit_value_4);//Get the value of single digit
delay(1);//loop delay update every 1 ms
void pickDigit(int x) //light up a 7-segment display
switch(x)
case 0:
digitalWrite(d1, HIGH); digitalWrite(d2, LOW);digitalWrite(d3, LOW);digitalWrite(d4, LOW);
case 1:
digitalWrite(d1, LOW); digitalWrite(d2, HIGH); digitalWrite(d3, LOW);digitalWrite(d4, LOW);
case 2:
digitalWrite(d1, LOW);digitalWrite(d2, LOW); digitalWrite(d3, HIGH); digitalWrite(d4, LOW);
case 3:
digitalWrite(d1, LOW);digitalWrite(d2, LOW);digitalWrite(d3, LOW);digitalWrite(d4, HIGH);
default:
digitalWrite(d1, LOW);digitalWrite(d2, LOW);digitalWrite(d3, LOW);digitalWrite(d4, LOW);
void pickNumber(int x)
switch(x)
case 0:
zero();
case 1:
one();
case 2:
two();
case 3:
three();
case 4:
four();
case 5:
five();
case 6:
six();
case 7:
seven();
case 8:
eight();
case 9:
nine();
default:
zero();
void clearLEDs()
digitalWrite(a, HIGH);
digitalWrite(b, HIGH);
digitalWrite(c, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
digitalWrite(g, HIGH);
digitalWrite(p, HIGH);
void zero() //display 0
digitalWrite(a, LOW);
digitalWrite(b, LOW);
digitalWrite(c, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
void one() //display 1
digitalWrite(g, HIGH);;
void two() //display 2
digitalWrite(g, LOW);
void three() //display 3
void four() //display 4
void five() //display 5
void six() //display 6
void seven() //display 7
void eight() //display 8
void nine() //display 9
void add()
if (digitalRead(machineon)==HIGH)
if (count < 10)
count ++;
count = 0;
if (seconds < 59) seconds++;
seconds = 0;
if (minutes < 59)minutes++;
minutes = 0;
if (hours < 23)hours++;
else hours = 0;
void downtime()
void display2()
int digit_value_5;
int digit_value_6;
int digit_value_7;
int digit_value_8;
if (digitalRead(machineoff) == HIGH)
// 1. Load number 1
digit_value_5 = seconds % 10;
digit_value_6 = (seconds / 10) % 10;
// 2. Load number 2
digit_value_7 = (minutes) % 10;
digit_value_8 = (minutes / 10) % 10;
pickNumber(digit_value_5);// get the value of thousand
pickNumber(digit_value_6);// get the value of hundred
pickNumber(digit_value_7);//get the value of ten
pickNumber(digit_value_8);//Get the value of single digit
void pickDigit1(int y) //light up a 7-segment display
switch(y)
case 0:
digitalWrite(d5, HIGH); digitalWrite(d6, LOW);digitalWrite(d7, LOW);digitalWrite(d8, LOW);
case 1:
digitalWrite(d5, LOW); digitalWrite(d6, HIGH); digitalWrite(d7, LOW);digitalWrite(d8, LOW);
case 2:
digitalWrite(d5, LOW);digitalWrite(d6, LOW); digitalWrite(d7, HIGH); digitalWrite(d8, LOW);
case 3:
digitalWrite(d5, LOW);digitalWrite(d6, LOW);digitalWrite(d7, LOW);digitalWrite(d8, HIGH);
default:
digitalWrite(d5, LOW);digitalWrite(d6, LOW);digitalWrite(d7, LOW);digitalWrite(d8, LOW);
void pickNumber1(int y)
switch(y)
case 0:
zeros();
case 1:
ones();
case 2:
twos();
case 3:
threes();
case 4:
fours();
case 5:
fives();
case 6:
sixs();
case 7:
sevens();
case 8:
eights();
case 9:
nines();
default:
zeros();
void zeros() //display 0
digitalWrite(A, LOW);
digitalWrite(B, LOW);
digitalWrite(C, LOW);
digitalWrite(D, LOW);
digitalWrite(E, LOW);
digitalWrite(F, LOW);
digitalWrite(G, HIGH);
void ones() //display 1
digitalWrite(A, HIGH);
digitalWrite(D, HIGH);
digitalWrite(E, HIGH);
digitalWrite(F, HIGH);
digitalWrite(G, HIGH);;
void twos() //display 2
digitalWrite(C, HIGH);
digitalWrite(G, LOW);
void threes() //display 3
void fours() //display 4
void fives() //display 5
digitalWrite(B, HIGH);
void sixs() //display 6
void sevens() //display 7
void eights() //display 8
void nines()
