code check
#include <Keyboard.h>
static byte rowPin[6]={7,6,5,4,3,2};
static byte colPin[15]={24,26,28,30,32,34,36,38,40,42,44,46,48,50,52};
static byte overrideKey=1;
bool keystate[90],prevKeystate[90],debouncedKeys[90];
unsigned long prevStateChanged[90],stateChanged[90];
unsigned char row1Layout[15]={'KEY_ESC','KEY_F1','KEY_F2','KEY_F3','KEY_F4','KEY_F5','KEY_F6','KEY_F7','KEY_F8','KEY_F9','KEY_F10','KEY_F11','KEY_F12','KEY_DELETE','KEY_INSERT'};
unsigned char row2Layout[15]={'`','1','2','3','4','5','6','7','8','9','0','-','=','KEY_BACKSPACE','KEY_PAGE_UP'};
unsigned char row3Layout[15]={'KEY_TAB','q','w','e','r','t','y','u','i','o','p','[',']',char(92),'KEY_PAGE_DOWN'};
unsigned char row4Layout[15]={'KEY_CAPS_LOCK','a','s','d','f','h','j','k','l',';',char(39),'KEY_RIGHT_SHIFT','KEY_RETURN','KEY_HOME'};
unsigned char row5Layout[15]={'KEY_LEFT_CTRL','KEY_LEFT_SHIFT','z','x','c','v','b','n','m',',','.','/','KEY_RIGHT_CTRL','KEY_UP_ARROW','KEY_END'};
unsigned char row6Layout[15];
void setup(){
  row6Layout[0]='KEY_LEFT_GUI';
  row6Layout[2]='KEY_LEFT_ALT';
  row6Layout[6]=char(32);
  row6Layout[10]='KEY_RIGHT_ALT';
  row6Layout[12]='KEY_LEFT_ARROW';
  row6Layout[13]='KEY_DOWN_ARROW';
  row6Layout[14]='KEY_RIGHT_ARROW';
  Keyboard.begin();
  for(byte temp=0;temp<6;temp++){
    pinMode(rowPinLed[temp],OUTPUT);(rowPin[temp],INPUT);
    digitalWrite(rowPinLed[temp],LOW);
  for(byte temp=0;temp<15;temp++){
    pinMode(colPinLed[temp],INPUT);(colPin[temp],INPUT_PULLUP);
  pinMode(overrideKey,INPUT_PULLUP);
void loop(){
  unsigned long lastLoop=millis();
  scanForKeys();
  debounceKeys();
  outputKeystrokes();
  configureBrightness();
  configureBacklight();
  outputBacklight();
  while(millis()-lastLoop<1){
    delayMicroseconds(70);
  while(digitalRead(overrideKey)==LOW){
    delay(100);
void scanForKeys(){
  for(byte temp=0;temp<90;temp++){                                                  //save all the current values to use later
    prevStateChanged[temp]=stateChanged[temp];
    prevKeystate[temp]=keystate[temp];
  for(byte rowTemp=0;rowTemp<6;rowTemp++){
    pinMode(rowPin[rowTemp],OUTPUT);
    digitalWrite(rowPin[rowTemp],LOW);                                              //make row pins work as ground one by one
    for(byte colTemp=0;colTemp<15;colTemp++){
      keystate[15*rowTemp+colTemp]=!digitalRead(colPin[colTemp]);                   //read keys that are pressed, one row at a time
      if(keystate[15*rowTemp+colTemp]!=prevKeystate[15*rowTemp+colTemp]){           //if the keystate has changed,
        stateChanged[15*rowTemp+colTemp]=millis();                                  //save the current time to debounce the key
    pinMode(rowPin[rowTemp],INPUT);                                                 //reset the row pins to their former state
  keystate[79]=!digitalRead(bnKey);                                                 //read the state of the key that is not in the matrix
  if(keystate[79]!=prevKeystate[79]){
    stateChanged[79]=millis();                                                      //save the current time to debounce the key
void debounceKeys(){
    if(stateChanged[temp]-prevStateChanged[temp]>50){                               //if the keystate is stable,
      debouncedKeys[temp]=HIGH;                                                     //the key is debounced
    }else{        //if not,
      debouncedKeys[temp]=LOW;                                                      //the key is not debounced
  if(stateChanged[79]-prevStateChanged[79]>75){                                     //debounce the standalone key
    debouncedKeys[79]=HIGH;
  }else{
    debouncedKeys[79]=LOW;
void outputKeystrokes(){
      if(debouncedKeys[15*rowTemp+colTemp]==HIGH){                                  //if the keystate changed stabily,
        if(keystate[15*rowTemp+colTemp]==HIGH){                                     //check the state. if its pressed, press the key
          if(rowTemp==0){
            Keyboard.press(row1Layout[colTemp]);
          if(rowTemp==1){
            Keyboard.press(row2Layout[colTemp]);
          if(rowTemp==2){
            Keyboard.press(row3Layout[colTemp]);
          if(rowTemp==3){
            Keyboard.press(row4Layout[colTemp]);
          if(rowTemp==4){
            Keyboard.press(row5Layout[colTemp]);
          if(rowTemp==5){
            Keyboard.press(row6Layout[colTemp]);
        }else{        //if its released, release the key
          if(rowTemp==0){
            Keyboard.release(row1Layout[colTemp]);
          if(rowTemp==1){
            Keyboard.release(row2Layout[colTemp]);
          if(rowTemp==2){
            Keyboard.release(row3Layout[colTemp]);
          if(rowTemp==3){
            Keyboard.release(row4Layout[colTemp]);
          if(rowTemp==4){
            Keyboard.release(row5Layout[colTemp]);
          if(rowTemp==5){
            Keyboard.release(row6Layout[colTemp]);
will the code function like a keyboard?
if you see errors, the post about it would greatly be appreciated
thanks in advance!
Does it compile? Probably not. Your use of single quotes around defined constants such as 'KEY_ESC' is wrong. In all cases it should be just KEY_ESC.
If it does compile, have you tried it?
Pete
On what hardware with what keyboard?
Mark
  while (millis() - lastLoop < 1) {
  while (digitalRead(overrideKey) == LOW) {
    delay(100);
Can you please explain the purpose of these two while loops, particularly the first one ?
tatic byte rowPin[6] = {7, 6, 5, 4, 3, 2};
static byte colPin[15] = {24, 26, 28, 30, 32, 34, 36, 38, 40, 42, 44, 46, 48, 50, 52};
static byte overrideKey = 1;
Why static ? Did you perhaps mean const ?
In the long term it is probably not a good idea to use pin 1 in case you need to use the serial monitor for debugging.
coolnumber0129:
Did you try it? What happened?
I think you're more likely to get help if you include links to any libraries you used.
The code didn't compile for me since I didn't have the "Keyboard.h" file.
el_supremo:
Pete
it does compile... hmmm....
will it work if it compiles?
holmes4:
Mark
15x6 switch matrix with cherry mx switches with an arduino due
im making a keyboard not interfacing with one
UKHeliBob:
    delay(100);
the first while loop is for limiting the loop at 1000times per second
because someone told me not to 'hog' the usb port whatever that means(have no idea what hogging is)
and the second one is for stopping all functions just in case something goes wrong and i have to
upload a clean code
i thought static made it so that the variable's value cant be changed?
is the use incorrect here?
how should i use it?
DuaneDegn:
i thought the keyboard.h is in the arduino by default...
and no i didnt try it because i was afraid of wrecking my board i bought with my allowance
<Keyboard.h> was introduced in IDE 1.6.6.
#if ARDUINO >= 10606
#endif
